It is currently Feb Mon 18, 2019 1:24 am
 Post subject: Roland 7TL ( 7TW wood cabinet ) project---sure a neat set !
PostPosted: Sep Thu 27, 2018 5:42 am
Hello All,
Had been looking for a leather Roland 7TL portable since receiving & refurbishing another smaller Roland set awhile back which turned out to be an excellent performer. The couple that came up on Ebay sold for more than I wanted to bid and doubted I'd ever find one... Then I saw this wood encased version recently which is first I'd ever seen on Ebay. It looked to be in decent condition, so bid a fairly high amount (for me) at last moment and won it for a reasonable figure...
Got it today and cabinet appears to be in nice shape and should clean up pretty well though the front and rear decals above speakers are worn away in areas. Looked like the grille cloth was loose in Ebay listing and turns out that it is actually perforated, embossed, anodized aluminum ! Radio is quite a bit larger than I thought, also... It worked just as described in listing with "scratchy" volume control. Someone had put a flat-head brass wood screw into phono input jack to engage contact so radio would play. Not the greatest sensitivity as it is and tone is very flat and "trebley"---hope new electrolytics and alignment will bring about big improvement ! Battery-Maker did a video on his awhile back and it's audio sounds similar---did you recap & align yours, Bill ???
Just finished wiring new detached garage tonight and a LOT more work yet to do on it and yard---and now bench covered with radios again ! Whew !!!
Below are a couple quick pics of this radio as received...
Stay tuned !
 Post subject: Re: Roland 7TL wood-encased portable project---sure a neat s
PostPosted: Sep Thu 27, 2018 2:03 pm
Very neat. I definitely like the wood case.
PostPosted: Sep Thu 27, 2018 2:47 pm
you're lucky i was on a budget... :mrgreen:
PostPosted: Sep Thu 27, 2018 3:00 pm
It's really neat John. Can't wait to see inside.
That's the radio... not the garage. Lol
https://www.radiomuseum.org/r/roland_71_486_ch_7tw.html
https://www.samswebsite.com/en/photofac ... sid/432_10
PostPosted: Sep Thu 27, 2018 3:20 pm
That a really great looking radio John. Congratulations.
I really like the styling.
It also looks to have a rotatable base similar to the NEC NT-71
PostPosted: Sep Thu 27, 2018 5:03 pm
This radio retailed for $79.95 in 1959. Compared to its original price, what you paid today is really a bargain.
The actual model is 7TW (W for wood). The 7TL refers to the leather model with identical chassis which was $10 less expensive. The 7TW came in five finish colors: Ebony, Mahogany, Walnut, Blonde and Fruitwood. The leather version debuted in two colors, tan and black; the maroon color was added later.
Curious on how the decals could be restored.
Binh
PostPosted: Sep Thu 27, 2018 10:53 pm
Thanks Guys !
Very grateful to have got it !
Shaun---it does have a rotating base, but wonder if the legs are bent up as the photo in the SAMS makes it look as though it should sit higher...
Binh---where did you find all the info on this set ? I just searched on-line... Would sure like to have a copy for project folder ! Funny thing is that the internal label states model 7TL !
PostPosted: Sep Fri 28, 2018 3:44 am
Esquire magazine July 1957
Super power 7-Transistor circuitry with exclusive Omnirange switch for longer range reception!
PostPosted: Sep Fri 28, 2018 1:19 pm
Hi John,
Some info for your set was found by searching ads and catalog pages sold on Ebay.
Here is an ad or a catalog page that featured the 7TL and 7TW:
https://i.ebayimg.com/images/g/lO8AAMXQBwlRJ6zr/s-l1600.jpg
https://i.ebayimg.com/images/g/pNkAAOxyvSVREWAI/s-l1600.jpg
A page from the 1958 John Plain catalog that featured the Roland Bi-Fidelity "4" and "7" (4TR and 7TL):
https://i.ebayimg.com/images/g/uH0AAOSw8w1X6aHf/s-l1600.jpg
An ad that appeared on July 28, 1956 in Billboard:
https://books.google.com/books/content?id=fUUEAAAAMBAJ&pg=PA44&img=1&zoom=3&hl=en&sig=ACfU3U0JFEH50qvtfDZOlQqmrKm3tfLacg&w=1347
The ad said that Roland was advertised nationally in Esquire (as Greg found out above) and Sports Illustrated.
Binh
PostPosted: Sep Fri 28, 2018 4:09 pm
All transistor 77
Closed listing (description): https://www.ebay.es/itm/232779980169
1600W (remaining) images from above listing...
https://embarrados.com/e-shop/item/2327 ... ransistors
PostPosted: Sep Fri 28, 2018 4:31 pm
Thanks much, Binh & Greg---images saved to folder !
Greg---neat to know that the 7TL came out in 1957 (thought I'd seen that somewhere before) ! And I had bid on that one from old Ebay listing...
Funny thing is that the "chintzy" "Omni-range" local/distance circuit is in the audio output---see below... Whoop-de-doo...
 Post subject: Re: Roland 7TL ( 7TW wood cabinet ) project---sure a neat se
PostPosted: Sep Fri 28, 2018 5:48 pm
F output---see below... unny thing is that the "chintzy" "Omni-range" local/distance circuit is in the audio Whoop-de-doo...
So where's the rear part of M4 connected to? According to the schematic that's just the front part of the switch.
PostPosted: Sep Sat 29, 2018 3:13 am
Hey Metzman---no other portion of switch M4 is shown in schematic !
Hope to have time to take it apart next week...
PostPosted: Oct Sat 06, 2018 4:50 am
Man---what a headache !
Took it apart the other day---not fun... Replaced electrolytics today---absolutely no difference in performance. Needed complete alignment as even the tuning dial was way off---performance much better now. But audio has same characteristics---except now much worse on stronger signals. Should sound good with those two 5" speakers ! Same with headphones. Same using signal tracer on IF output---so something is bad in IF chain, but what ??? Not enough time to cover troubleshooting detail, but am at a loss right now on what's going on.
Did a lot of cleaning/detailing, also---ready for parts pics and to go back together once electronics repaired...
More to come as time allows...
PostPosted: Oct Thu 11, 2018 4:56 am
Hello All,
Finally completed this set last weekend (except for resolving audio issues) !
Removing chassis no fun---even with instructions printed on label. Tight fit and ferrite rod antenna would not clear edge of cabinet, so removed it with small 1/4" open-end ignition wrench. After removal, noticed spring-steel tabs behind supports which allow antenna to be pushed inward for this process---live and learn !
Applied power with chassis on bench, jumpered electrolytics out of curiousity, and noticed no difference whatsoever in performance and audio quality---same after all were replaced. The original Japanese "Cosmic" caps were fine ! The four RF/IF transistors are socketed and the three audio soldered in place. Added a 9V battery clip for convenience keeping original wiring for "future owner". Radio required complete alignment as even the dial was way off. 1st IFT double-tuned. After alignment, performance much better, but strong local signals distorted. AGC voltage change seemed fine and found no component failures during troubleshooting except that the 1st IF transistor emitter resistor was twice its marked value. Thinking this may be problem, replaced with good part and no change. Replaced mixer & IF transistors, verified alignment, used signal tracer to verify "overload" but could find no cause---maybe design flaw ??? Need to contact Matt about his 7TL... The audio still flat/"trebley"---unbelievable with those two 5" speakers ! And it's not the audio amp circuit---used RF probe of signal tracer at 3rd IFT output and had same poor sound quality ! Tried de-tuning the IF's slightly, but only killed selectivity... Anyone have any ideas of what's going on ??? Ran out of patience and decided to put it back together for now... Watched Matt's 7TL & Bill's 7TW videos on You-Tube and both those sets sounded similar to this one, so am wondering if it's just a poor design ? My smaller Roland not only out-peforms this set noticeably, but sounds much better !
The cabinet cleaned up very well using just slightly damp, then dry cotton cloths and a few hours of careful rubbing. It's solid wood---well made and nicely finished. Used damp then dry Q-tips to remove all the grease residue in handle slots. The few nicks and scratches were taken care of with an old "Markette" brown marker I've had for many years (see pic below)---just applied to area and quickly wiped off excess with fingertips. Have done this with other wood radios and furniture and it works great !
The anodized aluminum trim strip on top was slightly twisted and bent, so carefully straightened it by hand. The thin plastic cover over tuning dial appeared to be made from similar material to what was used in earlier tube sets---cleared up pretty well with Novus-2 polish. Was very careful cleaning inside since ends and top appeared to be simply painted gold. Used water dampened, then dry inside-out cotton socks to clean the anodized aluminum speaker grilles and trim.
The swivel base is attached at center with larger thumbscrew which is also used to adjust "tightness" of rotation.
Inserted handle at end of assembly process to complete---simply slides in and metal tangs lock it into position.
Radio turned out to be a real beauty, but am VERY disappointed in performance and sound quality. Might get into it again one day when motivation returns and time allows... It is a large set---taller and wider than a GE P-780 !
Since it is a unique set, took a lot of pics for those who may be interested---three posts worth...
Would sure like to hear from others who have either this or the 7TL model concerning performance & audio issues !
PostPosted: Oct Thu 11, 2018 4:59 am
Here is the 2nd of three installments...
PostPosted: Oct Thu 11, 2018 5:03 am
Here is the 3rd and final installment of pics---please see previous posts for first two...
PostPosted: Oct Thu 11, 2018 4:38 pm
Beautiful!
PostPosted: Oct Thu 11, 2018 9:07 pm
OUTSTANDING work!
PostPosted: Oct Fri 12, 2018 3:51 am
Thanks very much, Guys !
Sure wish it worked/sounded good enough to enjoy---maybe get the scope on it this winter...
Post New Topic Post Reply  [ 30 posts ]  Moderator: Dave Doughty Go to page 1, 2  Next
Users browsing this forum: AuroraOldRadios and 4 guests
