It is currently Feb Tue 20, 2018 3:05 am
 Post subject: Ruby Micronic earphones?
PostPosted: Aug Thu 18, 2011 3:23 pm
http://cgi.ebay.com/STANDARD-MICRONIC-R ... 256097551d
Please look at the earphone plug. I have a very good Ruby which I use a lot, but can't find a plug that fits the jack. Jack is 2 tiny holes about 3/16 inches apart.
Anybody know a source for the jack? I'm only using solder tipped wires.
edit: http://www.radiomuseum.org/images/radio ... 242877.jpg
 Post subject: Re: Ruby Micronic earphones?
PostPosted: Aug Thu 18, 2011 6:51 pm
You might try hanging around the various computer connectors and pins at Fry's. I found similar plugs there for a little crystal set I had found among some dollhouse furnishings. It used them for the earphone and antenna/ground connections. They are not quite "right", but highly functional.
Ron Mc/
PostPosted: Aug Tue 23, 2011 10:55 pm
I might have a parts set with a headphone jack from my collection fo Micronic Rubies . Will look later this evening.
I will send you a PM if I do.
What are you using for batteries for the Micronic Ruby ?
Ken
PostPosted: Aug Wed 24, 2011 3:39 am
Hello I use earphone batteries size 675.
These 'air cells' lose power in a abt 3 weeks even if not used.
I suppose size also available in other chemistry types.
I use the Wumpus method minus the cardboard tube.
Just a screw and two nuts for a spacer in battery column.
Without the tube the batteries stay tight anyway because I
carefully filed down the screw to exact correct length.
http://www.oldradioworld.de/srh436.htm
Would love to get an earphone plug, thanks!
PostPosted: Aug Wed 24, 2011 5:49 am
thanks for info on the air cell battery. If it last only a few weeks, it wouldn't work for me. I don't play the radios that often.
anyways, I found a phone jack for a Micronic Ruby. Sent you a PM.
Ken
PostPosted: Aug Wed 24, 2011 5:54 am
After reading your posts again, I am not sure whether you are looking for the jack or the headphone plug.
:oops:
You mentioned plug in your last post.
Post New Topic Post Reply  [ 6 posts ]  Moderator: Dave Doughty
Users browsing this forum: Ed in SoDak and 8 guests
