It is currently Feb Sat 16, 2019 3:23 pm
 Post subject: MOTOROLA X48N DIAL BELT HELP
PostPosted: Feb Fri 02, 2018 4:45 am
I purchased a Motorola model X48N portable transistor and after I replaced the caps and aligned the radio the dial belt broke. The belt is
probably over 50 years old and I guess that was its life span. If anyone knows where I can get a replacement please let me know. Also
if you have any suggestions on a substitute please let me know. The belt length is 5" and its diameter is 1/16". Any help would be greatly appreciated.
UPDATE: Here is a new picture of the completed Motorola X48 ( 3rd picture down ).
 Post subject: Re: MOTOROLA X48N DIAL BELT HELP
PostPosted: Feb Fri 02, 2018 4:56 am
If it were mine, I would clean the ends with alcohol and try supergluing it back together. Nothing to loose. If that doesn't work, well....
PostPosted: Feb Fri 02, 2018 5:24 am
I appreciate your suggestion but I think that a permanent fix would be more appropriate because the belt is dry rotted and will most likely break in another spot.
PostPosted: Feb Fri 02, 2018 10:41 am
This should keep you going for a while!
Ten O-rings for less than four bucks + free postage from Hong Kong... Lol
https://www.ebay.com/itm/10-Pcs-40mm-x- ... SwEaBZ-amP
(a 2mm by) 40mm Diameter equates to a 5" Circumference... :)
https://www.omnicalculator.com/math/cir ... rence:5!in
PostPosted: Feb Fri 02, 2018 1:44 pm
Hi Greg,
I will first check my local auto store and hardware store to see if they have anything similar and if they don't I'll order the ones you mentioned.
Thanks for the great info.
Frank
PostPosted: Feb Fri 02, 2018 1:51 pm
I'll see if I have a belt in my o-ring assortment in
the shed.
Both of my Motorolas needed that drive belt.
Jim
PostPosted: Feb Fri 02, 2018 3:38 pm
Home Depot KOHLER O-Ring
Model # 1105656
Internet #203927809
79ยข
https://www.homedepot.com/p/KOHLER-O-Ri ... /203927809
Dimensions
Inside Diameter 1.25 in
Outside Diameter 1.549
Product Depth (in.) 1.549
Product Height (in.) .1
Product Width (in.) 1.549
Wall Thickness (in.) .1
PostPosted: Feb Fri 02, 2018 3:45 pm
Hi Jim,
I appreciate your help.
Probably a 1 1/4" to 1 1/2" diameter "O" ring should work.
Frank
PostPosted: Feb Fri 02, 2018 3:51 pm
Hi Greg, Thanks for the info. it sounds like it should work.
Today I will go to Lowes, Home Depot and Pep-Boys. Out of the 3 stores I hopefully should find a belt that works.
Frank
PostPosted: Feb Fri 02, 2018 4:04 pm
Very good Frank.
In the land of O-rings, it appears to be known as a...
Number-129
Who Knew... :shock:
PostPosted: Feb Fri 02, 2018 4:50 pm
Haven't got one. Sorry.
Jim
PostPosted: Feb Fri 02, 2018 6:07 pm
Hi Jim,
That's OK, thanks for looking. I just went to Lowes and Home Depot and I ended up purchasing a "O" ring assortment for $2.98. There were two large "O" rings inside and I think that one of them will work. I will let everyone know if it works.
Frank
PostPosted: Feb Sat 03, 2018 2:30 am
Hey Frank,
If o-ring is correct size or maybe a bit tighter, it should work.
Radio very similar to the X61E which both Jim & I have one of---looking forward to performance report !
PostPosted: Feb Sat 03, 2018 5:43 am
Hi John,
Your right, the "O" was a little tight putting it on but it works great. I can not believe how HOT this receiver is and it also has pretty descent sound with plenty of volume to spare. I am very happy with it.
It's definitely a keeper.
Frank
PostPosted: Feb Sat 03, 2018 5:00 pm
Hey Frank,
Glad it turned out well ! Looks like it will clean up great, also...
Got my X61E out this morning and am listening to my favorite DX oldies station---very good radios !
PostPosted: Feb Sun 04, 2018 3:26 am
i John,
I was probably listening to the same station. that you were listening to, was it 740 Zoomer radio ? Its a great station and I love the oldies that they play. Last night Zoomer radio was coming in so strong it sounded like a local station.
The Motorola X48 sure pulls in a lot of DX and sounds great.
Frank
PostPosted: Feb Wed 07, 2018 5:18 am
Performance Update:
The other day I took a short trip to the Jersey shore and took alone my Motorola X48N to see how well it would perform in a noise free environment. My target test station is WRYM 840 AM which runs only 1KW and is located approximately 80 - 90 miles north in New Britain, CT. I was really surprised how strong WRYM came in on my Motorola X48N as compared to all of my other radios that I own. Hands up to the Motorola engineers, they really designed a good radio.
PostPosted: Feb Fri 09, 2018 3:50 am
Hey Frank---Motorola made many excellent radios !
Glancing at the schematics, the X61 simply has one extra stage of audio amplification---the rest appears identical to the X48.
Be sure to post pics once you've shined it up !
Post New Topic Post Reply  [ 18 posts ]  Moderator: Dave Doughty
