It is currently Feb Thu 22, 2018 3:59 pm
 Post subject: Zenith Royal 12c diagram
PostPosted: Feb Thu 08, 2018 7:53 pm
Hi..is there anyone who has this diagram...it would help me out alot...
Zenith Royal 12C
Thanks..
Kenny KE4HVE
 Post subject: Re: Zenith Royal 12c diagram
PostPosted: Feb Fri 09, 2018 1:43 am
Service data for Zenith Royal 12C1 (Hong Kong) was published in Sams TSM-89
ebay $7.99 +free postage is an OK price... :)
https://www.ebay.com/sch/i.html?_from=R ... 2&_sacat=0
PostPosted: Feb Fri 09, 2018 6:06 am
HI.all I have no idea about this radio...I have worked on many many radios but this one got me...I worked on it for about an hour, and could not get anything...all of a sudden I seen 2 capacitors where the + side of the caps went to the Negative side of the battery....I have never seen this. I found this because I was recapping the radio...the last two caps was the 2 that went to the NEGATIVE side of the battery terminal, and it seems like the ground of the radio also.... So I installed the batteries backwards and the radio made a click..and a very faint signal came thru...I went thru with the recapping...and found 1 resistor bad or out of spec...and as of now it works with the batteries backward..
If the batteries are installed the right way it will not make a sound, nada..
Has anyone seen this before....
That is the reason I needed the diagram...
Kenny
PostPosted: Feb Fri 09, 2018 2:51 pm
Please don't run that radio with the batteries reversed. You will probably damage the transistors. The old zeniths had positive ground with the pnp germanium transistors. PM me. I will get you the service data.
