It is currently Feb Sun 17, 2019 11:48 pm
 Post subject: Handic Dutch CB - need to wire a mic to it
PostPosted: Jan Tue 30, 2018 11:50 pm
I got this one at a local hamfest, but for the life of me, cant figure out the wiring to my mic:
Yellow is mic I/p, shield, black is rcv, red is xmit.
See the attached schematic. which wire goes where? the dang DIN 4-pin is confusing as itself is not numbered. and from the scmematic, am I looking at thefront of the CB socket, or the back of the pins of the mic plug?
 Post subject: Re: Handic Dutch CB - need to wire a mic to it
PostPosted: Jan Wed 31, 2018 12:20 am
numbers upside down but info is there:
PostPosted: Jan Wed 31, 2018 1:29 am
I think I asked wrong. In the Sams schematic, what does pin view and wiring view mean? I must have something reversed in my wiring as the mic is always activated in transmit mode w/o any modulation. Mic is good as I tested it on a cobra 4 pin like manualman shows. Also it is a 4-pin DIN euro plug, not cobra type.
PostPosted: Jan Wed 31, 2018 1:59 pm
here is what the connector looks like I need to wire. Again, looking at the schematic, does "pin view" mean as I am looking at the "pins" of the plug, or the pins I solder to on the back of the connector? I assume "wiring view" is inside the CB itself?
PostPosted: Jan Wed 31, 2018 2:46 pm
Wiring view looks to be viewing the jack from the back where the wires are connected to the radio chassis.
Pin view would be looking at the pins from the front of the plug on the mic.
PostPosted: Jan Wed 31, 2018 9:38 pm
Pin view generally means looking into the actual pins that plug into something. You also need to confirm the microphone internal wiring of the mike element and switch so that you can mate the microphone and equipment correctly.
Post New Topic Post Reply  [ 6 posts ]  Moderator: Sandy
