I picked up this week what seems to be an earlier production of an HQ-170A (doesn't have the VHF tag on the faceplate). Although there was evidence of it sitting around in someone's basement for quite some time (crud on the chassis, mouse residence, etc.) I was able to clean it up nicely, swap out the 7 paper caps, and most of the resistors measured ok. Plays very well in all modes and although it could benefit from an alignment it appears to be pretty darn close.
The one concern I have is the filter cap. As standard practice when I work on a radio I replace the filter caps with either a new can or caps mounted underneath the chassis if sufficient room. In this case it clean one of the previous owners made some changes to the power supply. First, as shown in the pics C82A and C82B are shorted together. Second, at the junction of diodes CR1 and CR2 there is additional wiring along with a pair of 8uf @450V electrolytics in parallel. The additional wiring goes to L6 which I believe is an 8H filter choke ( I think this is a standard component in the 170, 170A and 180). I'm trying to understand why this was done. Carl (WA1KPD) and I speculated that possibly L6 bit the dust and the extra capacitance was needed (although 16uf seems to be negligible) while the 100uF (combined C82A and C82B) would help. Why not just add a 300 to 500 ohm resistor? Or did the previous owner try to solve two other issues...(a) add the electrolytics in parallel to deal with the low level AC hum typical of Hammarlund receivers and (b) quick recourse to a weak filter cap without replacement.
The receiver works very well with no discernible hum, audio distortion, etc.
Thoughts?
Thanks...Harry WE1X
