It is currently Jun Tue 19, 2018 3:15 pm
 Post subject: Hallicraters S-119 Sky Buddy II hum
PostPosted: Feb Thu 01, 2018 6:26 pm
Hi gang -
My friend's Sky Buddy II is in need of some electronic TLC. Upon power-up and tube warm-up, I get a loud hum with no reception. The hum is independent of volume control and band switch position.
My thought is that it is the electrolytic can cap (C9A,B,C), and it appears to be the only "one" electrolytic (actually, three). All the rest of the caps are ceramic or Duramica types.
Knowing the history of this receiver, it appears to be a time-related issue. He hasn't used it in years, and I personally remember this set working at one point. Hence, I suspect it's a capacitor decay issue, and not a blown tube(s). I'll test the tube voltages against the S-119 manual values, before recapping.
Any ideas regarding this hum? The set looks easy enough to troubleshoot, even for me...
Bob T.
 Post subject: Re: Hallicraters S-119 Sky Buddy II hum
PostPosted: Feb Thu 01, 2018 6:49 pm
Replace the dry electrolytic multi-cap.
PostPosted: Feb Thu 01, 2018 10:10 pm
Indeed - the trick is finding the right metal can (here, it's a 60/60/20 mfd with 175/150/25 V rating, respectively). Otherwise, I'll have to build one out of discreet parts.
-Bob T
PostPosted: Feb Thu 01, 2018 10:14 pm
https://hayseedhamfest.com/collections/ ... ers?page=2
PostPosted: Feb Fri 02, 2018 4:06 am
Why not disconnect the three electrolytic cap sections and temporarily wire in three caps, ballpark close in value, from your parts bin? If the radio works, then you can order a proper replacement part.
On mine, I confess I just snipped the leads from the original cap but left it in place on top of the chassis. Underneath, I used new individual caps from my collection. I also replaced the three audio coupling caps and the AVC line cap at that time; nothing seemed wrong with them, but at 60 years old, their time on earth is coming to an end.
Rob
PostPosted: Feb Sat 03, 2018 7:52 pm
I checked the hayseedhamfest.com site, and they don't have an S-119 recap kit. I checked all the other models for a 60/60/20 mfd, but no luck. I will, however, drop them a line regarding my needs/wish list.
As for using discreet caps from the workbench, modern electrolytics usually have only certain values available. So, would a 68/68/22 mfd work in place without compromising (original) performance?
Bob T.
PostPosted: Feb Sat 03, 2018 8:48 pm
Your 68 and 22 MFD are fine for replacements.
KK6IYM
PostPosted: Feb Sat 03, 2018 11:36 pm
Thanks, Norm (et al). That's good to hear.
I put a quote request in at hayseedhamfest.com. We'll see later. Now I have to find some metal mesh to replace the front speaker grill...
-Bob T.
PostPosted: Feb Sun 04, 2018 6:19 am
Bob, The loud hum does sound like the power supply electrolytics are bad, but could also be something else. It's probably a good idea to power it up using a variac so as not to load down or stress other components in the power supply until you're sure other components won't be damaged. If you don't have one, try to borrow one. Have fun.
Regards, Larry
PostPosted: Feb Mon 05, 2018 6:12 pm
How critical are the voltage ratings for electrolytics? Exact matches seem tough to find. The 60/60/20 mfd I need is rated 175/150/25 V. Is it better to get higher rated voltages?
PostPosted: Feb Mon 05, 2018 8:17 pm
Get higher voltage rated capacitors. They are small and inexpensive as long as you just go a step higher in voltage--50V for 25V rated, 250V for the 68 MFd's.
KK6IYM
PostPosted: Feb Mon 26, 2018 9:57 pm
Just a follow-up: Houston, we have audio!
Hayseed made a 3-section cap for me, with higher voltage ratings. AM (CW) works just fine, no hum on any band. I'll have to wait until night to test the shortwave reception, though.
Thanks, all!
-g
ps: I think I'll save the recapping of my S-38 as a retirement project. LOL!
Post New Topic Post Reply  [ 12 posts ]  Moderator: Sandy
