It is currently Feb Tue 19, 2019 1:41 pm
 Post subject: Receiving VLF SAQ Grimeton with simple equipment at home
PostPosted: Feb Mon 12, 2018 7:53 pm
The traditional transmission with the Alexanderson 200 kW alternator on VLF 17.2 kHz from Grimeton, Sweden, can be received with ferrite antenna and regenerativ audion technique. Quality is low, distance is 500 km to Berlin, Germany. But it is possible. https://www.youtube.com/watch?v=I0luIo78fIg
 Post subject: Re: Receiving VLF SAQ Grimeton with simple equipment at home
PostPosted: Feb Tue 13, 2018 4:05 am
Talk about digging it out of the noise. Impressive!
Knowledge is useless unless you can share it. KA5OBI
PostPosted: Feb Tue 13, 2018 10:06 pm
If bandwidth is too high or too small the signal to noise ratio decreases. As shown in a diagram in the video: to correctly detect the morse signals you need a higher bandwith for a short "dit" than for a long "da". About the middle of both is therefore the best.
The resonant circuit itself and the position of the feedback coil determine the bandwith. In the realtime FFT spectrum you can watch a wide signal resulting from feedback just bevore oscillation occours (screenshot in video). In addition the smaller signal from morse patterns sits than at 17.2 kHz on top. I hope this description is understandable.
Post New Topic Post Reply  [ 3 posts ]  Moderator: Sandy
