It is currently Sep Wed 19, 2018 2:02 pm
 Post subject: Heathkit IT-28 Cap Checker Resistors Getting Pretty Hot
PostPosted: Mar Mon 12, 2018 7:39 pm
Guys,
I'm recapping and changing out the resistors in my IT-28. The 4 47K 2W and the 33K 2W resistors are getting quite hot. Like 265 degrees F. Is this normal?
IT-28 Schematic.pdf [215.35 KiB]
Downloaded 19 times
Crist
 Post subject: Re: Heathkit IT-28 Cap Checker Resistors Getting Pretty Hot
PostPosted: Mar Mon 12, 2018 9:01 pm
Seems a little hot to me. Did you replace the two 40uf? I use 47uf at 450 volt. Did you check the wiring and parts against the assembly manual?
PostPosted: Mar Mon 12, 2018 9:18 pm
Yeah, I used some 47uf 450V too. Yeah I checked everything against the manual.
Crist
PostPosted: Mar Mon 12, 2018 10:54 pm
Look at the schematic.
The 33k resistor is a power supply bleeded with 200 volts on it.
That is 1.2 watts of dissipation, which can feel quite hot.
The 47k resistors are part of a series/parallel arranged voltage dropper for the range swith.
Those resistors total 8 watts so major dissipation is expected there.
