It is currently Feb Fri 22, 2019 11:47 am
 Post subject: Moved post to vintage receivers...
PostPosted: Feb Wed 14, 2018 1:28 pm
MOVED
 Post subject: Re: 12.6vct to 6.3v single ended?
PostPosted: Feb Wed 14, 2018 1:37 pm
No, the transformer only does 3 amps. You can split the 6.3v loads into two halves to use the 12.6.
Scott.
PostPosted: Feb Wed 14, 2018 1:45 pm
I would have thought the design would be based on Power dissipation.
 Post subject: Re: Moved post to vintage receivers...
PostPosted: Feb Wed 14, 2018 1:49 pm
It is the diameter of the wire in the windings that is the issue. You double the current and the heat losses quadruple (P=I*I*R).
Scott.
Post New Topic Post Reply  [ 4 posts ]  Moderators: Marcc, Norm Leal
