It is currently Jan Wed 24, 2018 5:00 am
 Post subject: Zenith Bee Hive Speaker.
PostPosted: Apr Mon 09, 2012 2:56 pm
Inactive
Were these speakers all the same pin outs and field coils. In other words, should work in any chassis that requires the Bee H. speaker.
 Post subject: Re: Zenith Bee Hive Speaker.
PostPosted: Apr Mon 09, 2012 3:54 pm
They were electrically different, depending on the field coil requirements of the particular chassis. For example, those used on a 12 tube push-pull chassis used a speaker with a lower field coil resistance than those used on the 9-toobers. The beehives themselves were identical for the 9 and 12 tube models AFAIK, but the beehives for the 15-toobers had a bigger cut-out on the inside to accommodate the larger output transformer on the speaker. You could probably use a 15-tube beehive with any speaker, but you couldn't use a 9 or 12 tube beehive on a 15-tube speaker.
Bob
PostPosted: Apr Tue 10, 2012 11:09 pm
Inactive
Bob
Heres the number on the bee hive speaker S5604 K. How do I find whichZeniths used this part #?
PostPosted: Apr Tue 10, 2012 11:27 pm
Do you have the speaker that it came with? You could tell that way. I dont think you can tell from the bee-hive #.
Is there a part # on the speaker frame? Should be 49-XXX. The last 3 digits will correspond to the model #.
PostPosted: Apr Tue 10, 2012 11:34 pm
Inactive
I asked the owner to pull the bee hive and tell me the number on the speaker. He wrote back and said there wasn't a number on the speaker. Oh well.
PostPosted: Apr Wed 11, 2012 4:49 pm
Inactive
Found out the number 49 AB 185 Whats it match up with???
After research I answered my own question, (9S -262, 263, 264 all 12" speakers.
Post New Topic Post Reply  [ 6 posts ]  Moderators: Marcc, Norm Leal
