Page 1 of 1
[ 8 posts ] |
| Author |
Sirtar
Post subject: Help reading a schematic GE 216 Posted: Aug Sat 04, 2012 11:21 pm |
I'm replacing the C37A,C37B Electrolytic 80mfd 40 mfd But on the schematic drawing It reads C37B, C37D So which one is the 80mfd? Also i only have a 100mfd, can i use it for the 80?
I try to send the schematic with this message but i don't know how to?
| Top |
Norm Leal
Post subject: Re: Help reading a schematic GE 216 Posted: Aug Sat 04, 2012 11:34 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 29147 Location: Livermore, CA
Hi I found a 218 with those designations: http://www.nostalgiaair.org/PagesByMode ... 007621.pdf This one uses a selenium rectifier with resistor before the 1st filter cap. Since they take plate power for the output tube off 1st filter cap this section should be a high value, 80 mf. Are you replacing the selenium rectifier with a 1N4007 silicon diode? This diode can easily handle surge current of a higher filter cap value. http://www.diodes.com/datasheets/ds28002.pdf
_________________ Norm
| Top |
Sirtar
Post subject: Re: Help reading a schematic GE 216 Posted: Aug Sat 04, 2012 11:49 pm |
yes i will be replacing the selenium rectifier with resistor. I have a 100ohm 5w resistor to use. Will the 100mf be to big?
Thanks for the reply.
| Top |
Norm Leal
Post subject: Re: Help reading a schematic GE 216 Posted: Aug Sat 04, 2012 11:55 pm |
A 100 mf first filter cap will be ok but be sure to add a 1N4007 or similar diode. Not just another resistor.
| Top |
mugginsjr
Post subject: Re: Help reading a schematic GE 216 Posted: Aug Sun 05, 2012 12:07 am |
| Member |
Joined: Apr Fri 13, 2012 10:48 pm Posts: 1153 Location: Hebron, Ky
Hi Norm... just browsing through and saw your comment about the selenium rectifier. Do think it best to always replace those? I have a radio on my "unknown problem" shelf that I haven't been able to diagnose yet, but the rectifier seems to be working ok.... Is it fooling me? John
_________________ Sometimes, I guess there just aren't enough rocks. -Forrest Gump
John R...
| Top |
Norm Leal
Post subject: Re: Help reading a schematic GE 216 Posted: Aug Sun 05, 2012 12:21 am |
You will get differences of opinion about replacing selenium rectifiers. Over time voltage drop increases so output will be less. You don't want to be around a selenium rectifier that gets shorted. It gives off a smell like rotten eggs, worse.
Most Zenith T/O's that I've come across have low B+ voltage due to aging selenium rectifiers. A silicon diode like 1N4007 only costs a few cents and will last for decades.
If your shelf radio is a battery/AC/DC type a selenium rectifier with high voltage drop may be the problem?
I don't want to start the selenium rectifier debate again. It's up to an individual if they replace a selenium rectifier. Some are still in use and operating over 60 years.
| Top |
mugginsjr
Post subject: Re: Help reading a schematic GE 216 Posted: Aug Sun 05, 2012 12:26 am |
| Member |
Yes, it is an AC/Battery model..... I'll check that B+ voltage again.... Good tip, thanks..... And I'm going to stock up on those 1N4007's. You say they can handle house current with no problem, right?
John R...
| Top |
Norm Leal
Post subject: Re: Help reading a schematic GE 216 Posted: Aug Sun 05, 2012 2:53 am |
1N4007 is rated 1000 volts @ 1 amp but they can withstand 1 cycle of 30 amps. Won't have that in radios.
| Top |
