Page 1 of 1
[ 2 posts ] |
| Author |
frankradio1
Post subject: Hallicrafters S-77 question Posted: Nov Sat 03, 2012 7:24 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 821 Location: Germantown, IL USA
Hello, The schematic shows a 110 ohm, 10 watt resistor across the heater of V-5, a 6H6. All the tubes are in series and have 300 Ma heaters, so I don't understand the need for this resistor. Why is it necessary to lower the heater voltage on the 6H6?
Tom Ackerman
| Top |
Dave Doughty
Post subject: Re: Hallicrafters S-77 question Posted: Nov Sat 03, 2012 8:15 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13649 Location: Utica, NY 13502 (USA)
In some cases, it was found that the 6H6 and other detector tubes work better at a slightly reduced filament voltage. A resistor in parallel with the filament when the tube is in a series string filament circuit will accomplish this. If the tube were in a parallel connected filament circuit, there would be a resistor in series with the 6H6 filament. Maybe someone else can explain why the tube works better with a reduced filament voltage.
| Top |
Users browsing this forum: Tommgb and 4 guests |
