It is currently May Sun 27, 2018 6:04 am
 Post subject: Vacuum tube pin diagram
PostPosted: Jan Thu 10, 2013 8:40 pm
I have been using nostalgiaair.com to print out diagrams of the various vacuum tubes I'm working with but for the past week the "tube" part of that site dose not work (get errors). Is there another site on the Web that I can get this info from? Thanks. Tom
 Post subject: Re: Vacuum tube pin diagram
PostPosted: Jan Thu 10, 2013 9:00 pm
Radiomuseum: http://www.radiomuseum.org/tubes/tube_6al5.html
But the search is a bit quirky.
Avoid throwing electronics out as you or someone else might need them for parts or use.
PostPosted: Jan Thu 10, 2013 9:07 pm
There are lots of tube data sites:
http://frank.pocnet.net/
PostPosted: Jan Thu 10, 2013 9:42 pm
Tom I use this site for tube data.
http://www.nj7p.org/Common/Tube/SQL/Tub ... hp?index=1
Gordon
Better to remain silent and be thought a fool than to speak out and remove all doubt.
A Lincoln
PostPosted: Jan Thu 10, 2013 9:50 pm
Find a copy of RCA's "Triple Pindex" (1959) more than 2000 JEDEC pin-outs of popular tubes, multi-ring bound and stacked as three copies one above the other. Three different pin-outs can be displayed at once making it convenient to have open on the bench for reference while working on a chassis...
http://www.ebay.com/itm/1959-RCA-Triple-Pindex-Receiving-Picture-Tube-Base-DIAGRAM-GUIDE-/150970491607
As useful as I find this, I'm surprised that it has not been re-printed...
Chas
PostPosted: Jan Thu 10, 2013 11:13 pm
Thanks for all the sites. One tube I'm unable to find the pin layout for is a 7D7. This tube is in a Philco model 41-296 which I an currently working on.
PostPosted: Jan Thu 10, 2013 11:26 pm
You will find it on page 201. Have download the whole book, however.
http://frank.pocnet.net/other/docs/MK-RT.pdf
PostPosted: Jan Thu 10, 2013 11:39 pm
An old MIL tube guide says it has an 8AR base pinout.... same as 7J7.
PostPosted: Jan Thu 10, 2013 11:58 pm
The online tube search on Duncanamps will find info on specific tubes, and the answer set will usually include equivalent tube substitutions (and also similar, but not equivalent) answers. The search answers usually show the pinout and common tube parameters. Saves a lot of guesswork, especially when it comes to things like filament current...
The answers will also give links to the tube data at N7JP, as well as original (GE, Sylvania, etc) tube docs as pdf's.
http://www.duncanamps.com/tdsl/tubesearch.php
HTH
Jimmie
PostPosted: Jan Fri 11, 2013 1:25 am
Thanks Again. Tom
Post New Topic Post Reply  [ 10 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: nash, Usually Lurking and 14 guests
