Page 1 of 1
[ 3 posts ] |
Author |
David Smiecinski
Post subject: Philco 41-290 I.F. transformer problem Posted: Feb Mon 16, 2004 10:57 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 24 Location: Austin, TX United States
I am restoring the chasis of a Philco 41-290 console radio which has sentimental value to me. I have just started learning the basics of tube radio. After replacing the electrolitic capacitors on the radio. I found that the first I.F. transformer looked different internally from the second, so I took the cover off of it and found the windings were missing from the spool. I figured that is why the radio doesn't pick up any stations. Does anyone know where I can find info on rebuilding or replacing the transformer?<P>------------------<BR>
Top |
Norm Leal
Post subject: Philco 41-290 I.F. transformer problem Posted: Feb Mon 16, 2004 11:03 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 37194 Location: Livermore, CA
Hi David<P> Here is a list of some available IF Transformers.<BR> <A HREF="http://www.oldradioparts.com/2a6fla.txt" TARGET=_blank>http://www.oldradioparts.com/2a6fla.txt</A> <P> Are you sure the coil is missing? There are some IF Transformers where coils are close together.<P>------------------<BR>Norm
Top |
David Smiecinski
Post subject: Philco 41-290 I.F. transformer problem Posted: Feb Tue 17, 2004 12:54 am |
Thank you Norm for the Transformer info. <P>The I.F. Transformer is in pieces and most of the pieces were inside the can which was eattached to the radio. There are four small pieces of thin coil wire on the wax and cardboard tube that the coil was rolled on. I was able to look at the 2nd I.F. transformer which looks like it was built the same way. <P>Thank you again for your help!!! now back to work<P>David<P>------------------<BR>
Top |
