It is currently Feb Fri 15, 2019 10:14 pm
 Post subject: Zenith Have no Am/Fm where should I start?
PostPosted: Feb Mon 05, 2018 7:16 pm
Thanks for looking at my post!
I just recapped this zenith I do have output in the amplifier its working good. But I have 0-Zero Am or Fm reception where would you start schematic Below,
 Post subject: Re: Zenith Have no Am/Fm where should I start?
PostPosted: Feb Mon 05, 2018 8:59 pm
doing some voltage testing
Q201 1st am-fm Amp
C=12v
B & E = I have NO volts
Where does the voltage come in from here?
PostPosted: Feb Mon 05, 2018 9:23 pm
Hi Mark
Voltages start on page two, toward the right. Squares numbered 1 through 5, marked source. Measure there and work back through resistors and coils.
PostPosted: Feb Mon 05, 2018 10:16 pm
Thanks Norm Found it to much solder in the 10mfd cap it connected +/- together.
PostPosted: Feb Tue 06, 2018 12:00 am
one-page schematic. jpg
http://a4.pbase.com/o10/56/215056/1/166 ... titled.jpg
PostPosted: Feb Tue 06, 2018 3:24 am
Thanks for the one page schematic :)
PostPosted: Feb Tue 06, 2018 5:30 am
So is it fixed?
PostPosted: Feb Tue 06, 2018 6:22 pm
Yes traced it back to a cap I replaced had the solder connecting the +/- together.
PostPosted: Feb Tue 06, 2018 6:53 pm
You should always not do that as often as you can. :)
PostPosted: Feb Wed 07, 2018 10:50 am
If not even more often!
Post New Topic Post Reply  [ 10 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: 37oldsguy, AJJ, Dutch Rabbit, joeztech, Robert Buntzel, simplex1040, Tim Tress and 19 guests
