It is currently Feb Fri 15, 2019 10:14 pm
 Post subject: Schematic Needed for a FADA Model 160-A
PostPosted: Feb Sun 04, 2018 8:21 pm
I pulled 2 off the Radiomuseum.org site. One doesn't match my particular set; the other matches, but the person who drew it used only lines - no markings indicating if crossing wires are connected or not. As you can imagine, it's really confusing.
Barring a schematic, if you can tell me the Primary and Secondary connections for both XFMRs, that would help. Both were removed on the unit I came across.
Thanks!
 Post subject: Re: Schematic Needed for a FADA Model 160-A
PostPosted: Feb Sun 04, 2018 9:02 pm
Does this match your radio?
http://www.nostalgiaair.org/pagesbymode ... 005369.pdf
PostPosted: Feb Sun 04, 2018 9:12 pm
Fada One Sixty schematic here...
http://americanradiohistory.com/hd2/IDX ... e-0026.pdf
The complete issue (Radio News, May 1931) can be downloaded here...
http://www.americanradiohistory.com/Rad ... _Guide.htm
PostPosted: Feb Mon 05, 2018 12:01 am
Norm Leal wrote:
Sorry. Should have been more specific.
It's the 1923, 4-tube model 160-A.
"egg" sent me a link that should help. I had something similar to it already, but mine still had gaps.
Thanks!
PostPosted: Feb Mon 05, 2018 12:02 am
Thanks! I'll give that one a try.
PostPosted: Feb Mon 05, 2018 1:06 am
The page Norm linked to includes the earlier four-tube schematic...
PostPosted: Feb Wed 07, 2018 4:26 am
New XFMRs in place, but performance is a bit lacking. As it sits right now, there's no grid leak (one schematic shows it, others don't), so I'll add it in. Can't hurt anything. Tuning the middle coil is a bit tricky, as body capacitance interferes.
However, I think my biggest problems have been the same with all the radios: weak tubes, insufficient antenna and a poor earth ground. Still, I'm getting a signal, so I'm on the right track!
Thanks for the help!
PostPosted: Feb Wed 07, 2018 6:28 am
Yikes! What an unconventional schematic!
The draftsman drew the wires that crossed as NOT connected, any single wire touching and having no wire continuing is a connection. In other words, placing a connection dot on all tee junctions should be correct.
The set is probably NOT neutralized. A tube with an open filament and not shorting will work, or some means like a piece of tape on the filament contact of the tube socket.
The dummy tube is installed in the 1st RF and the radio tuned. The neutralizing condenser is adjusted for minimum signal. Test the setting across the entire tuning dial and pick the best compromise. Replace the dummy with a good tube and then put the dummy in the 2nd RF, repeat, done... Do not re-adjust the neutralizers for any reason except changes in wiring in the RF section or use of totally different tubes like something from the DeForest line... Then you would need a dummy DeForest and more tape :)
This is just a triode detector, NO grid leak required...
He, he, got yourself another reflex, :lol:
Chas
"Gandhi"
PostPosted: Feb Fri 09, 2018 10:34 pm
The kind of schematic that causes seizures!!
I'll give that a try. I haven't touched them yet.
One schematic had it, one didn't, and then there's that nightmare schematic. I figured it couldn't do any harm. Will be easy to remove, though.
Post New Topic Post Reply  [ 9 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: 37oldsguy, AJJ, Dutch Rabbit, joeztech, Robert Buntzel, simplex1040, Tim Tress and 18 guests
