It is currently Feb Fri 15, 2019 10:29 pm
 Post subject: Capacitor Questions
PostPosted: Feb Wed 07, 2018 4:48 pm
Another in the series of Newbie questions brought to you by...me.
I'm working on a Hallicrafters S-38B. I've got the paper caps replaced and installed a polarized plug. It works great, but I'd like to make sure before I button it up, I've done all I can.
I've run across a few domino caps but most of them are mica so I'm not too worried about them. However, there's one type I've never seen before. The body color is a light clay color. It's attached to two high accuracy resistors. I've upload a picture for your perusal. Is this a paper cap as well? Replace?
Secondly, there's a multi-capacitor package that I'm not sure I should replace (also pictured below.) My understanding is that it's a ceramic package so might not need to be replaced. Opinions?
Thanks to you all for your kind help through the years!
Best,
Cliff
 Post subject: Re: Capacitor Questions
PostPosted: Feb Wed 07, 2018 4:53 pm
If it were me, I would leave both alone.
Your set is working.
PostPosted: Feb Wed 07, 2018 6:04 pm
Hallicrafters part number-46A151 is a four-section ceramic capacitor/s.
Known, back in the day as a... PEC (printed electronic circuit) or Couplate.
C11A C11B C11C and C11D
5000pF 220pF 220pF and 2000pf
should be in the parts list... :)
PostPosted: Feb Wed 07, 2018 6:12 pm
electrolytics replaced?
-Mark http://pixellany.com
PostPosted: Feb Wed 07, 2018 8:16 pm
Yes, the electrolytics have been replaced.
PostPosted: Feb Wed 07, 2018 8:18 pm
Yes, the PEC is in the parts list, but should it be replaced?
PostPosted: Feb Wed 07, 2018 8:28 pm
I wouldn't replace the PEC couplate. Those caps are ceramic and should be fine.
PostPosted: Feb Thu 08, 2018 5:26 pm
As simplex1040 said, just leave it as it is.
If the domino cap is attached to tight tolerance resistors it is unlikely to be a paper or similar.
Since the PEC, couplate, is all capacitors it should be fine. The couplates that also contain resistors sometime have drifted resistor, I think this is because the process of manufacture is a compromise. Many times those have connection such as you can't measure all the components.
Tim
Post New Topic Post Reply  [ 8 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: 35Z5, joeztech, lorenz200w, nomad, ychris and 13 guests
