It is currently Feb Sat 23, 2019 6:15 am
 Post subject: Gulbransen model 60 chassis safety cap
PostPosted: Feb Fri 09, 2018 1:46 am
I have been told to use a y2 safety cap for c-17 on the wiring diagram. I cannot find a good replacement for this. A suggestion would be great. Thanks!
 Post subject: Re: Gulbransen model 60 chassis safety cap
PostPosted: Feb Fri 09, 2018 4:57 am
You can purchase the needed cap from this supplier:
http://www.justradios.com
Your info is correct- the replacement cap should be a type Y2 "safety" cap.
PostPosted: Feb Sat 10, 2018 1:54 am
...Sal, Digikey, and Mouser have them too...
PostPosted: Feb Sat 10, 2018 2:24 am
The schematic calls for a 0.02-uF, 750-VDC capacitor, and yes a Y2 or an XY2 cap is appropriate here. You should keep the same capacity (0.02-uF) as it probably protects the on/off switch from arcing when the contacts open, in addition to putting the chassis at RF ground. The new Y2 capacitor will be rated for 250-VAC which is a modern rating system that tells you the maximum line voltage the cap should be used on. If you dig up a spec sheet on it, you'll see that Y2 caps are tested to much higher voltages.
Any good quality X or Y type capacitor will have manufacturers' ID or certifications marked on it that identify which standards it meets. It's important to check for this, otherwise the cap might not really be what you think it is. See https://www.allaboutcircuits.com/technical-articles/safety-capacitor-class-x-and-class-y-capacitors/ for further info.
Thomas A. Edison
PostPosted: Mar Sun 04, 2018 3:21 am
I was looking at Mouser and I found this: https://www.mouser.com/ProductDetail/Mu ... dTqEN38%3d
I would like to check to see if this will work before I buy. Thanks!
PostPosted: Mar Sun 04, 2018 3:46 am
That's a 0.0022-uF cap; you need 0.02-uF. Other than that it looks like it would work.
Thomas A. Edison
PostPosted: Mar Sun 04, 2018 3:49 am
I did notice that but so far I cannot find a 0.02 uF.
PostPosted: Mar Sun 04, 2018 4:04 am
Look to the right of this page at Sal's or Justradios. Both have Y2 capacitors in 0.01-uF (two in parallel give 0.02-uF); one has larger sizes if you prefer to go that route.
Disclaimer: these are cited only as convenient examples; you can find similar components at other distributors if you prefer.
Thomas A. Edison
Post New Topic Post Reply  [ 8 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Tube_Enthusiast and 5 guests
