It is currently Feb Sun 17, 2019 2:35 pm
 Post subject: Philco 40-190 help.
PostPosted: Mar Tue 06, 2018 11:46 pm
I finished one of these for a customer last year and liked the way it turned out. So I found another one to keep. I found an issue with this one that I didn't have in the first. What I thought was a bad capacitor, turns out according to the schematic to be a RF coupling trans. 32-3194. I'm not familiar with this. By the looks, I am assuming this one's shot. ? Any info would be appreciated. The PDF file for the schematic is too big and I am unable to reduce it. Sorry. It connects between the 7J7 and 1232 tubes.
 Post subject: Re: Philco 40-190 help.
PostPosted: Mar Wed 07, 2018 12:38 am
Philco part number 32-3194 is an R.F. coupling coil.
viewtopic.php?p=2410933#p2410933
schematic: http://www.nostalgiaair.org/Resources/339/M0013339.htm
oh... the stylized→ ω represents the lowercase Greek letter omega.
PostPosted: Mar Wed 07, 2018 1:54 am
Why did you cut it out? Did you measure the resistance?
PostPosted: Mar Wed 07, 2018 2:06 am
Performix Liquid Electrical Tape... :)
Walmart: 1003203
PostPosted: Mar Wed 07, 2018 2:23 am
I was doing my initial visual to check for anything that might need attention. Saw this and without consulting the schematic, cut it out thinking it was a bad capacitor. Thought I might see some markings after I pulled it. My bad. It does have continuity, and has a resistance of 4.5. Does it need replaced and if so do I need to find a parted out one or are there replacements?
PostPosted: Mar Wed 07, 2018 3:06 am
Advice (on your R.F. coupling coil) from lorenz200w and Ted can be seen in the link I posted directly underneath the schematic snippet above.
Me... I would scrape the remaining legs clean with a sharp x-acto knife and solder new extended legs to them...
I like to use plenty of liquid flux and... clean/remove the flux residue afterwards... :)
The following is... More relevant/important when working on circuit boards, but it makes for good practice.
Clean (and dry) with IPA (isopropyl alcohol) using a small acid brush or an old toothbrush. I use 70% (strength) isopropyl alcohol... mixed 50/50 with regular nail varnish remover (acetone), it leaves no residue.
In a past life I have used Zippo lighter fluid (naphtha) or denatured alcohol in a pinch. :)
PostPosted: Mar Wed 07, 2018 3:12 am
Thanks egg. Missed the link the first time.
Post New Topic Post Reply  [ 7 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: amphicar770, brnhornet52, crgrbrts, Exabot [Bot], spsquires and 19 guests
