It is currently Jun Tue 19, 2018 5:37 pm
 Post subject: Atwater Kent 337
PostPosted: Feb Thu 22, 2018 4:57 am
Replaced capacitors, electrolytics, and several bad resistors. The question I have is does anyone know the pin voltages? The AK schematic does not show those values. Also, how do I check the coils? Continuity or Ohms? what should those values be. I hear noise from the speaker, but that's it. Any information would be much appreciated.
 Post subject: Re: Atwater Kent 337
PostPosted: Feb Thu 22, 2018 5:07 am
The Rider schematic gives all the voltages.
http://atwaterkent.info/TechData/Images/Rider6_017.gif
Unfortunately they're white letters on a black background, and sometimes difficult to read.
You can look for that Rider page on other sites.
This is one of those AK schematics that uses an inverted omega to mean Megohms.
So "0.1 inverted-omega" means 0.1 Megohms = 100,000 ohms.
PostPosted: Feb Thu 22, 2018 5:25 am
Leigh,
Thanks I see them now. What about coils?
PostPosted: Feb Thu 22, 2018 5:31 am
Coils generally fail open rather than shorted.
If you measure continuity, they're likely OK.
The antenna coil primary is often open due to proximate lightning strikes.
PostPosted: Feb Fri 23, 2018 2:12 pm
Checked the coils all have continuity. Noticed a wire that needs to be replaced and will check for bad solder joints. Will report back. Thank you.
PostPosted: Mar Sun 04, 2018 6:45 pm
Replaced multiple wires connecting to coils brittle cracked and touching the chassis. Also, the heater wires were very brittle replaced as well. Heater voltages and plate and grid voltages on the 5Z4 are within specification. I hear a little noise coming from the speaker but no reception. What should be the next course of action to check? Thanks.
Post New Topic Post Reply  [ 6 posts ]  Moderators: Marcc, Norm Leal
