It is currently Sep Tue 25, 2018 11:42 pm
Post New Topic Post Reply  [ 52 posts ]  Go to page 1, 2, 3  Next
 Post subject: Using a FM transmitter for home
PostPosted: Mar Mon 05, 2018 7:53 pm
What do you think of using a FM transmitter in a home to broadcast a device like an Iphone or Ipod? I did not know these things existed, at least with the strength that they are advertised with. Here is one that looks reasonably priced:
https://www.amazon.com/Signstek-Broadca ... dpSrc=srch
This looks like an easy solution for me since I am interested in playing audio through my vintage radios on different flloors of my home at the same time. Does anybody care to comment on what the audio quality will be with one of these? It sure looks like the range will be plenty.
 Post subject: Re: Using a FM transmitter for home
PostPosted: Mar Mon 05, 2018 8:26 pm
Are your "vintage" radios FM?? A std broadcast radio isn't going to receive it's signal..
PostPosted: Mar Mon 05, 2018 8:59 pm
Yes, of course they are FM.
PostPosted: Mar Mon 05, 2018 9:32 pm
For a long time I used one of those car FM transmitters that were originally sold so that you could broadcast from a CD player (before they became a regular fit into cars) - ran it from a 12v wallwart and it covered my house alright. Then I found a kitset FM transmitter and coupled with a EBay MP3 SD card player works really well in a little disused speaker box.
Cheers - Martin ZL2MC
PostPosted: Mar Tue 06, 2018 12:03 am
I have one of these. It works very well. The low power setting covers my entire house with a very clean and stable signal.
Steve Chambers
Last edited by Steve Chambers on Mar Tue 06, 2018 2:32 am, edited 1 time in total.
PostPosted: Mar Tue 06, 2018 2:18 am
I have one of these and am very happy with it. I bought the kit and put it together.
Canakits has some other FM transmitters with added bells and whistles like blue tooth interface.
It has good range and fidelity.
https://www.canakit.com/hi-fi-stereo-fm ... uk222.html
Paul
...... how hard can it be?
PostPosted: Mar Tue 06, 2018 2:50 am
Steve and Paul,
How is the volume when you have your FM radio tuned into your transmitters? Does the volume match what you are getting from normal local FM stations? Do these transmitters seem to be broadcasting your source with complete frequency response?
BB
PostPosted: Mar Tue 06, 2018 3:01 am
Plenty of volume and excellent fidelity with this: https://www.amazon.com/Signstek-Broadca ... dpSrc=srch
The range on low power is more than adequate.
Steve Chambers
PostPosted: Mar Tue 06, 2018 3:05 am
Steve and Paul,
BB
Left and right channel line adjustment pots allow setting FM modulation to compensate for low input levels. Can be set to sound as loud as broadcast FM stations.
Paul
PostPosted: Mar Tue 06, 2018 3:25 am
Paul,
Can you tell us how long the 9 volt battery lasts before it needs replaced?
PostPosted: Mar Tue 06, 2018 3:43 am
I got one of those C.Crane FM2 transmitter some time ago. I was disappointed with the range. The power output isn't stated, but from the enclosed info it says range 30-75 ft. I measured much less maybe mine is defective. It could be the power is low because they were concerned with FCC part 15.
PostPosted: Mar Tue 06, 2018 4:36 am
https://www.ebay.com/itm/FM-Radio-Trans ... ation-DIY/
Various prices, free international shipping it says. This is the same chip that's in my little transmitter.
PostPosted: Mar Tue 06, 2018 4:49 am
Paul,
I have no idea how long it would operate on battery.
Mine is in an enclosure with a telescoping antenna and it runs off a separate 12 volt power supply. There is a 12 volt power option where you add a resistor to the circuit board.
It operates 24-7.
Paul
PostPosted: Mar Wed 07, 2018 5:29 pm
I have been using one of these for over a year,
https://www.ebay.com/itm/Car-Kit-LCD-3- ... Swv9hW1wu9
A bit of searching and you could probably get a better price, I did. FM stereo for the house and then some. Use it with XM radio, bluegrass 24/7, powered by usb port.
PostPosted: Mar Thu 08, 2018 4:20 am
I received this transmitter today and I must say it works much better than I expected. It feels like a high quality device, not the cheap made in China feel I expected. It has two power settings and I have been running it on low power and it easily broadcast to all three floors of the house. I have not tested how far away from the house it is transmitting but I will tomorrow using my car. As strong as the signal is in my house I figure it will probably go about 50 yards or so. The frequency response seems full and the output level can actually be turned up high enough that it will play louder than the loudest local Rock and Roll FM station. Stereo separation seems normal or at least on par with regular FM broadcasts. On my vintage German radios it is definitely a better sounding alternative to plugging the iPod directly into the "tape" or "phono" inputs. As we all know these old radios play surprisingly strong and loud with the FM radio but sound a little thin or flat when using the "tape" or "phono" inputs so this is quite an improvement over using those inputs. Looks like I have a great sounding solution to listening to my iPod on my old radios.
BB
PostPosted: Mar Thu 08, 2018 3:14 pm
I got the chance this morning to see how far away from the house this transmitter is reaching and I was surprised to be able to get good reception up to 1200 feet away. Does anybody know if this is a problem with violating some kind of rule or law? I think that may be a bit too far to be acceptable. The transmitter was set on it's lowest setting when I tested this. The transmitter is in the basement about 5 feet below ground level. If this is a problem is there a way to cut the transmitter power to an acceptable level.
BB
PostPosted: Mar Thu 08, 2018 6:20 pm
I'd like to know what the rules are also.
I assume you set it to broadcast on a frequency that doesn't have a station in your area.
If you don't interfere with someone else's reception you might be OK anyway. RF transmitters might be prone to damage if they don't "see" the proper antenna impedance, otherwise switching to another (smaller) antenna would cut down on range. You might use some type of attenuator between the transmitter and the antenna.
PostPosted: Mar Thu 08, 2018 8:08 pm
Unlicensed transmitter operation in the FM band is exceedingly restrictive and is allowed only when verifiable field intensity measurements are conducted and kept on file for each installation.
PostPosted: Mar Thu 08, 2018 8:09 pm
Regardless of the law, rules, or legal penalties, it's just good practice not to interfere with your neighbor's radios.
The actual FCC (part 15) rules say unlicensed FM transmitters should not have an effective range over 200 feet:
https://www.fcc.gov/media/radio/low-pow ... ion#PART15
"What goes around comes around." (Karma)
PostPosted: Mar Thu 08, 2018 8:31 pm
Push the antenna down until you get the coverage you want without going too far down the road........
Post New Topic Post Reply  [ 52 posts ]  Moderator: Alan Voorhees Go to page 1, 2, 3  Next
Users browsing this forum: Alan Voorhees, JAYoung, Tkilboy, WoodchuckTN, Y2KEDDIE and 9 guests
