It is currently Sep Thu 20, 2018 11:16 pm
 Post subject: Mongormery ward movie dial cabinet veneer replacment
PostPosted: Jan Tue 16, 2018 2:02 pm
New project, little movie dial cabinet overhaul. Getting a fresh makeover.
File comment: Cabinet veneer was bad shape and the top was wavy.
File comment: Base shelf was shot so I was forced to fab a new better stronger assembly.
File comment: Nice and fresh
File comment: Wood on wood walnut, one sheet.
File comment: Veneer is glued down and rolled out
File comment: This is a lot nicer wood veneer than what was on the cabinet before. An up grade if you ask me. Owner will be amazed, does not have to be factory looking.
File comment: Timbermate neutral grain filler
 Post subject: Re: Mongormery ward movie dial cabinet veneer replacment
PostPosted: Jan Mon 22, 2018 5:30 am
Hi Fred, beautiful work as usual....
What is the filler you used in the 1st picture?
And what glue do you use when replacing large sections of veneer?
Thank you!
PostPosted: Jan Mon 22, 2018 1:58 pm
Finished up cabinet, I used contact cement on this one. High strength #90 3m , don't ever use contact cement on paper back veneer especially when using lacquer clear, it may try in lift a few years down the road. I always use wood on wood veneer, I am using yellow glue on a lot of veneer jobs as well. I use polyester body filler , bondo for filler.
PostPosted: Feb Mon 05, 2018 5:22 am
What's the model number?
JR
PostPosted: Feb Mon 05, 2018 10:43 am
Looks beautiful!
Not sure about contact cement ?
Why ? you were doing fine without it
thanks Gary
PostPosted: Feb Mon 05, 2018 1:16 pm
JR
I don't remember model number on the movie dial radio.
PostPosted: Feb Mon 05, 2018 1:25 pm
Radio Fixer wrote:
Looks beautiful!
thanks Gary
Im going to start using yellow glue on all veneer work, this job i had ran out of yellow glue and I had 2 news cans of 3m high strengh left over, so i used them up. I have radios that i have used contact cement on 7 years ago and still holding tight, but still, yellow glue is the way to go or hide glue.
PostPosted: Feb Mon 05, 2018 1:26 pm
Good lord Fred,
You really do magic!
PostPosted: Feb Mon 05, 2018 1:40 pm
Is yellow glue better than white? Is the yellow Titebond?
thanks (sorry to keep asking questions that have already been asked, must keep better note)
Gary
PostPosted: Feb Fri 09, 2018 2:30 am
Yellow glue as far as I know is commonly used for veneer and can be activated after is has dried using heat from an iron. Ironing on veneer is done using yellow glue for many folks. I am not a veneer expert but learning a lot from doing it, reading and getting on the internet. I would love to some day be able to do any veneer job from scratch and have it turn out perfect.
PostPosted: Feb Sat 10, 2018 10:18 am
Thanks Fred, you are doing great work. Bet you could do a perfect job with all veneering now having so much experience.
Have to replace the veneer on the stepped sides of a cabinet that are only about 2" wide and the depth of the cabinet. Wondered if I could have everything prepped and glue the strip directly? No iron, just treating it as you would a piece of wood. Idea is to get a piece of thick Perspex cut and clamp it across the whole cabinet with long clamps. Would it work?
thanks Gary
PostPosted: Feb Sat 10, 2018 2:38 pm
I don't see why not, go for it.
PostPosted: Feb Sun 11, 2018 12:38 am
Fred I wouldn't give up on contact cement, I have cabinets that were veneered 20 years ago using Weldwood contact cement and still looking good. I still use the yellow on smaller areas on a cabinet and of coarse the joints.
Larry in NC
PostPosted: Feb Tue 13, 2018 4:59 pm
fred taylor wrote:
Radio Fixer wrote:
Looks beautiful!
thanks Gary
Yes it is.
http://russoldradios.com/
PostPosted: Feb Mon 19, 2018 4:12 pm
Hello Fred,
i work anyway where do you get your veneer ?
That set will really look great when your done.
Sincerely Rich
PostPosted: Feb Tue 20, 2018 3:19 am
radiorich wrote:
Hello Fred,
Sincerely Rich
I get my veneer at Wood World here in Dallas also I get smaller pieces off ebay
Post New Topic Post Reply  [ 16 posts ]  Moderator: Peter
Users browsing this forum: calmark and 3 guests
