It is currently Jan Sat 19, 2019 7:20 am
 Post subject: Timbermate-What now?
PostPosted: Jan Sun 28, 2018 2:07 am
I know that several of you have used Timbermate as a grain filler-my first usage is on a Grebe MU-1 cabinet. I have to admit to putting it on way to heavily and spending much more time sanding than I should have. So what now? directly to stain-in my case Mohawk very dark walnut mixed with 15% black, I will then finish with the very dark walnut lacquer. While the wood is mahogany, the finish was a very dark brown/black-at least on my unit, so should I use a sealer of some kind before the stain (oil ) or after stain but before lacquer.
Thx for the help
Abe
 Post subject: Re: Timbermate-What now?
PostPosted: Jan Sun 28, 2018 2:55 am
After sanding the grain filler off you are ready for some color, stain your cabinet over the grain filler, do all you toning . Now you can seal the cabinet, I use Mohawk EZ vinyl clear sealer . Once that has dried you can sand that smooth using 240 grit or finer , careful not to burn thru into your stained wood. Now your ready for the lacquer top coats of your choice, normally a satin finish.
PostPosted: Jan Mon 29, 2018 1:52 am
Thx for the direction Fred-will pick up the stain and sealer tomorrow and get on with it later in the week. Might post some pics as I go, but this is a small job compared to what many of you do.
Abe
PostPosted: Feb Sat 03, 2018 12:16 pm
Timbermate is a good product, because it can work with all finishes.
Easy to sand , mix and match filler, mixes up nice and thin .
Are you laying nitro? And a wash coat?
Pete
Vintage Tv's ! When Television was worth watching !
