Page 1 of 1
[ 7 posts ] |
Author |
Chris in TC
Post subject: GE E-86 project Posted: Jan Mon 29, 2018 1:47 am |
Joined: Dec Sun 21, 2014 5:03 am Posts: 222 Location: Traverse City, MI 49684
Top |
wowsk
Post subject: Re: GE E-86 project Posted: Jan Mon 29, 2018 1:16 pm |
Joined: Jul Mon 25, 2016 11:34 am Posts: 351 Location: Wilton IA
Wow it is looking good!
Great job, Noah
Top |
Chris in TC
Post subject: Re: GE E-86 project Posted: Jan Tue 30, 2018 3:05 am |
Tonight it got a wash coat of shellac, which is getting me closer. It's interesting that GE was so frugal, using cheap veneers on the sides and grille. There's real walnut on top and around the knob/dial area, but the rest is some very plain white wood. Most manufacturers used more walnut. But the stain helped and pretty soon it will be better. I found a grille cloth that looks very similar to the original. Later tonight I'll paint the new speaker baffle board with some flat black or maybe some old dark-brown shellac.
Chris Campbell
Top |
Chris in TC
Post subject: Re: GE E-86 project Posted: Feb Mon 12, 2018 3:53 am |
OK, I'm going to risk my blood pressure level by trying to post a current photo. The E-86 now has a bunch of layers of varnish, and after it sets out for a few days I'll start rubbing it out. Working in brushed varnish is a lot more time and labor intensive than for you guys who can spray lacquers but it is my option. It can turn out pretty well. I used a gloss varnish from Sherwin-Williams (harder to come by these days; everybody wants to sell polyurethane). It was hard to keep a wet edge as it came from the can so I have been adding Floetrol to make it level better. Let's see if I can perform a miracle and get the photo added. Remember--it will be rubbed out.
Chris Campbell
Attachments: |
Top |
Chris in TC
Post subject: Re: GE E-86 project Posted: Feb Mon 12, 2018 3:57 am |
Replying to myself. Sorry about the two identical photos--it didn't seem to take the first try. Usually it shows an indication when an attachment has been added.
That grille cloth is glued to its backer board, a new one I made to replace the corrugated cardboard one on the original. It's just propped up back there for the photo. The cloth came from one of our suppliers and is a quite-close match to the original in both color and pattern. Not perfect, not NOS, but very good. The portions of the old stuff that had been exposed were badly faded and I used the unexposed portions for matching.
Now I'm looking for knobs in the classified section. Anybody got 1936 GE knobs?
Chris Campbell
Top |
Chris in TC
Post subject: Re: GE E-86 project Posted: Mar Mon 12, 2018 1:35 am |
I've been working on the radio in the usual small sequential steps that such projects always involve. After varnishing, I wet sanded or steel-wooled, then rubbed with pumice and rottenstone. Then some areas needed some more varnish, sanding, and rubbing. Today I declared it "good enough" and applied paste wax. Then I mounted the new speaker baffle board (the original was cardboard) and the speaker. The grille cloth, as noted before, is very close to the original as it looked under the grille where it was not faded.
This isn't perfect--some of the veneer isn't glued perfectly--but it is good enough to fool amateurs. And since the device was two steps from the burn pile when I got it, it's a big step up.
The bezel is out on the garage heater with lacquer drying. I'll put that on later tonight.
Chris Campbell
Attachments: |
Top |
Chris in TC
Post subject: Re: GE E-86 project Posted: Jan Sun 27, 2019 1:30 am |
My E-86 project stalled when spring came last year. Then it was time to get the sailboats ready and other early-summer work. When the days are long and warm, I'm outdoors, not in the shop. But now it's deep winter and I've been turning to electronic restoration. A previous worker had replaced most of the Candohm voltage divider with individual wirewound resistors. The two filter electrolytics were replacements (old) and the rectifier had been replaced. All that evidence of power supply trauma had me nervous so I pulled the rectifier and plugged it in the radio to check the power transformer--bingo, high voltage! So I went ahead and replaced the electrolytic caps and all the rubber-coated wire that was adjacent to anything it might short out to (i.e., most of it). Tonight I checked the tubes; all OK except one very dead 6K7, an original GE tube. I had one of those in my tube stash so in it went. Now I'm waiting for an order of more capacitors--safety caps to replace the original line caps, a high-voltage cap across the output transformer primary, and a dual-section electrolytic. I have freed up the volume pot which must have been lubricated with some oil that petrified. The rolling dial scale was also seized up with stiff lubricant so that got cleaned and freed. The chassis has been cleaned up. It will be fun to see if it functions when it powers up.
Chris Campbell
Top |
Page 1 of 1
[ 7 posts ] |
Moderator: Peter |
Users browsing this forum: No registered users and 4 guests |
