It is currently Dec Tue 11, 2018 5:51 am
 Post subject: Zenith 9S367 band switch yoke
PostPosted: Feb Fri 02, 2018 10:53 pm
Today we're working on a Zenith 9S367. The band switch yoke is broken. Does anyone have any idea(s) where to get another one? It appears that someone in this radio's past life soldered the switch so that the band could not be moved. How about any ideas on how to fix this?
As always, thank you for all input!
Best wishes,
Diane
Hi friends,
 Post subject: Re: Zenith 9S367 band switch yoke
PostPosted: Feb Fri 02, 2018 10:57 pm
Post a WTB in the ARF Classified, switch assembly or a parts chassis...
Can also email Playthings of Past too...
http://www.oldradioparts.com/
Chas
"Gandhi"
PostPosted: Feb Fri 02, 2018 11:58 pm
How about some JB WELD.
PostPosted: Feb Fri 23, 2018 4:10 am
Looks like your band switch yoke is broken. I had the exact same issue on mine. It is made of pot metal. I found a replacement recently on ebay from a guy who was parting out a 9S367. He didn't list that part but I thought he should have it. So I contacted him and he listed it. There a c clip that needs to come off near the end of the shaft that goes through it. It should come loose after the clip is removed. This is a key part because it has linkage to the bandswitch and shutterdial. Concentric controls go through it for the manual tuning and volume control.
-Jon
We are the only normal ones.
