It is currently Feb Sat 16, 2019 8:22 pm
 Post subject: White Bakelite?
PostPosted: Feb Sat 03, 2018 9:53 pm
I just finished up this guy, a GE L610, and am curious as to just what the cabinet is made of. I thought it was plastic when I got it, but after cleaning it up it appears to be Bakelite - but white? Radio Museum says it is plastic, not Bakelite.
I'd rather be on the ground wishing I was in the air,
than in the air wishing I was on the ground.
 Post subject: Re: White Bakelite?
PostPosted: Feb Sat 03, 2018 10:17 pm
In a concealed location apply a red hot pin, the oder should be of phenol if it is a thermosetting resin like Bakelite and should not melt but char. If it is any thermoforming resin, it will melt and give a styrene glue like oder.
A "Q"-tip with acetone or lacquer thinner will melt most thermoforming plastics, whereas same solvent on Bakelite like thermosetting resin will do nothing.
http://www.sdplastics.com/plastics.html
YMMV
Chas
"Gandhi"
PostPosted: Feb Sun 04, 2018 12:09 am
Bakelite was made in many different colors.
PostPosted: Feb Sun 04, 2018 1:19 am
I applied a soldering iron tip to an inconspicuous spot. It did not melt, but charred and smelled awful, almost like burning hair. So, I guess Bakelite. It really looks nice.
Thanks all.
PostPosted: Feb Sun 04, 2018 3:35 am
The cabinet material is known as Plaskon, not bakelite.
David
PostPosted: Feb Sun 04, 2018 5:04 am
Thanks for that. I Googled Plaskon and learned a lot. It does indeed allow some light through, I can dimly see the pilot lamp through it.
I noticed that the inside of the top of the cabinet was painted "silver", which had peeled from heat over the 35Z5 and 50L6 (supposed to be a 35L6). So I applied some aluminum tape to reflect some of the heat. Fortunately the cabinet has not endured any damage.
It was essentially a freebie. I bought a Sentinel 68B from a fellow, and he asked if I wanted this one included since he was going to toss it. It looked like crap, but what a jewel.
PostPosted: Feb Sun 04, 2018 5:23 pm
FYI I have seen strange changes to the color of a white Plaskon" cabinet when exposed to the sun. Have set out a number of such radios at an outdoor radio flea. A tag remained on top of the cabinet for several hours. At the end of the day there was a "shadow" on the top of the top of the white radio which now looked "dirty".
I set the radio aside for several months and the radio, apparently, faded again and the image of the tag disappeared. The cabinet returning to its original, lighter color...
"Gandhi"
Post New Topic Post Reply  [ 7 posts ]  Moderator: Peter
