Page 1 of 1
[ 7 posts ] |
Author |
rebrands
Post subject: White Bakelite? Posted: Feb Sat 03, 2018 9:53 pm |
Member |
Joined: Jan Wed 11, 2012 5:12 pm Posts: 603 Location: Colorado Springs, CO
I just finished up this guy, a GE L610, and am curious as to just what the cabinet is made of. I thought it was plastic when I got it, but after cleaning it up it appears to be Bakelite - but white? Radio Museum says it is plastic, not Bakelite. Attachment:
Attachments: |
_________________ I'd rather be on the ground wishing I was in the air, than in the air wishing I was on the ground.
Top |
Post subject: Re: White Bakelite? Posted: Feb Sat 03, 2018 10:17 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13441 Location: S. Dartmouth MA 02748-1225 USA
In a concealed location apply a red hot pin, the oder should be of phenol if it is a thermosetting resin like Bakelite and should not melt but char. If it is any thermoforming resin, it will melt and give a styrene glue like oder. A "Q"-tip with acetone or lacquer thinner will melt most thermoforming plastics, whereas same solvent on Bakelite like thermosetting resin will do nothing. http://www.sdplastics.com/plastics.htmlYMMV Chas
_________________ First they ignore you, then they laugh at you, then they fight you, then you win. "Gandhi"
Top |
Sol
Post subject: Re: White Bakelite? Posted: Feb Sun 04, 2018 12:09 am |
Member |
Bakelite was made in many different colors.
_________________ I don't believe in experts. That's why I take my car to a plumber and my taxes to a chef.
Top |
rebrands
Post subject: Re: White Bakelite? Posted: Feb Sun 04, 2018 1:19 am |
Member |
I applied a soldering iron tip to an inconspicuous spot. It did not melt, but charred and smelled awful, almost like burning hair. So, I guess Bakelite. It really looks nice. Thanks all.
Top |
David Willenborg
Post subject: Re: White Bakelite? Posted: Feb Sun 04, 2018 3:35 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1776 Location: Hollywood, Maryland
The cabinet material is known as Plaskon, not bakelite.
David
Top |
rebrands
Post subject: Re: White Bakelite? Posted: Feb Sun 04, 2018 5:04 am |
Member |
Quote: The cabinet material is known as Plaskon, not bakelite. Thanks for that. I Googled Plaskon and learned a lot. It does indeed allow some light through, I can dimly see the pilot lamp through it. I noticed that the inside of the top of the cabinet was painted "silver", which had peeled from heat over the 35Z5 and 50L6 (supposed to be a 35L6). So I applied some aluminum tape to reflect some of the heat. Fortunately the cabinet has not endured any damage. It was essentially a freebie. I bought a Sentinel 68B from a fellow, and he asked if I wanted this one included since he was going to toss it. It looked like crap, but what a jewel.
Top |
Post subject: Re: White Bakelite? Posted: Feb Sun 04, 2018 5:23 pm |
Member |
FYI I have seen strange changes to the color of a white Plaskon" cabinet when exposed to the sun. Have set out a number of such radios at an outdoor radio flea. A tag remained on top of the cabinet for several hours. At the end of the day there was a "shadow" on the top of the top of the white radio which now looked "dirty".
I set the radio aside for several months and the radio, apparently, faded again and the image of the tag disappeared. The cabinet returning to its original, lighter color...
Top |
Page 1 of 1
[ 7 posts ] |
Moderator: Peter |
Who is online |
Users browsing this forum: No registered users and 3 guests |
