It is currently Feb Sat 23, 2019 9:39 am
 Post subject: Eico 660 Self Service Tube Tester, broken top glass
PostPosted: Sep Thu 06, 2018 7:19 pm
I came across a self serv Eico 660. Having flatbed printers at work is nice. I made up a new top glass.
Working out the final sizing and fit, turned out well.
I wonder if there is an interest in these with stock artwork, or customized, personalized artwork.
This is my 1st piece, have already reworked the art to have the dot count right, the dots across the image.
edit 666 to 660.
 Post subject: Re: Eico 666 Self Service Tube Tester, broken top glass
PostPosted: Sep Thu 06, 2018 9:51 pm
First one for trial fit shows a bit thick and image needs lowered. It should backlight well.
Would like to find some interesting images to use, a cartoonish guy holding a tube and lightning bolt.
Open for ideas and links.
I'll print a new one on thinner stock. I can't print white, but I can print on white.
Using an Oce' Arizona 250GT to do these, it's a flatbed printer that I revived at the shop after it sat idle for about a year.
This was printed on a clear sheet, then the backside painted flat white.
PostPosted: Sep Wed 12, 2018 4:45 am
hello Glue ru,
well your sign turned out very nice it looks great
Sincerely Richard
PostPosted: Sep Wed 12, 2018 3:43 pm
Thanks Richard. Now that I have the size and thickness resolved I came up with a couple designs.
PostPosted: Sep Thu 13, 2018 2:07 pm
That doesn't look like any Eico 666 I've ever seen.
Unemployed Analog Meter Technician. Simpson 260 specialist.
John, KK6WHY
PostPosted: Sep Fri 14, 2018 12:18 am
the middle one is the Eico 660 normal, the orange is a bit off in this pic, the light blue and black are my own design choices.
Anything can be printed. The final print/cut files are not for public release.
I'll probably print the stock version tomorrow providing I can get on the Arizona for a bit.
 Post subject: Re: Eico 660 Self Service Tube Tester, broken top glass
PostPosted: Sep Fri 14, 2018 4:05 am
Sal, Sal's Capacitors, has one on his site, looks yellow and do most on images found on google and yahoo.
Any references to factory colors is appreciated.
http://www.tuberadios.com/eico660/
Post New Topic Post Reply  [ 7 posts ]  Moderator: Peter
