It is currently Nov Thu 23, 2017 3:06 am
Post New Topic Post Reply  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: Powerup Box
PostPosted: Nov Mon 13, 2017 2:41 am
Really nice work. Is there any way you could share the part numbers of your components and the circuity you used?
PostPosted: Nov Mon 13, 2017 4:35 am
Absolutely! I'll post exactly what I ordered, but I'll tell you that I'm considering replacing the 3A meter with a 1A meter. I went with 3A because I know some radios draw close to an amp, plus I thought I might use this box for things other than radios. But I've found that this meter barely registers when the radio is pulling 0.25A so I think a 1A meter would be more useful. The again, it does show me if the current is spiking, which is really it's purpose since I installed the digital meter. Anyway, here are the parts:
All Electronics:
Power Switch: CAT# LRS-40
Ammeter: CAT# PMA-3A
Voltmeter: CAT# PMA-150V
Fuseholder: CAT# FHPM-31
Amazon:
Digital Meter: https://www.amazon.com/gp/product/B00YY ... UTF8&psc=1
The AC input connector I scavenged from a computer power supply. You'll also need a standard AC outlet.
Here's a pdf of the schematic. Sorry it isn't cleaned up...since it was for my own use I didn't bother making it pretty ;)
https://drive.google.com/file/d/1Q141rw ... sp=sharing
PostPosted: Nov Mon 13, 2017 9:52 pm
Thanks so much. The schematic seems straightforward. What did you do for the connections to the digital meter? On Amazon it looks like I'd need to connect to the meter with a plug.
PostPosted: Nov Tue 14, 2017 1:57 am
They're just screw terminals. Loosen the screw, insert the wire, tighten the screw. Easy peasy!
PostPosted: Nov Tue 14, 2017 11:34 pm
Thanks. My bad. Didn't notice there were screws
Users browsing this forum: analog.tv, Don Cavey and 9 guests
