It is currently Feb Sat 16, 2019 2:14 pm
 Post subject: Heathkit 0-5 Oscilloscope(s)--FINALE
PostPosted: Jun Sat 20, 2009 10:18 pm
Hello all,
This is a new thread to update all of you who helped me with my very long thread (ended about a week ago) trying to rebuild my 1950 Heathkit 0-5 oscilloscope.
When I left off the last thread I had purchased a second 0-5 for parts and also a repro manual. Today I received both of them. The circuit diagram showed that you guys were "on the money" in making your diagnosis and suggesting measurements I should make even without the proper schematic.
The parts oscilloscope came with a 5BP4 CRT (white trace instead of green). Substituting that tube for my 5BP1 seems to have solved the problem. The 5BP4 is well used so I need to have the intensity pot up near the max to get a nice trace BUT the trace does not dim after a min or two and, in fact, stayed the same for 10 min that I tried it.
So now I have looked at three CRTs for this scope. The original 5BP1 which was very dim right from the start; the replacement 5BP1 purchased a while ago online which may be gassy? because it starts out quite bright and then gets very dim after a min or two and stays very dim; and finally the replacement 5BP4 which came with the parts oscilloscope which is in the middle in terms of brightness BUT it doesn't change and is quite useable if I keep the room fairly dim.
The parts oscilloscope turns out to be complete and untouched as far as I can tell since 1950. It has all original caps and resistors and a horribly rotted line cord. It has not been plugged in for a long long time based on the very rotted line cord. I think I will replace the line cord and make some careful tests with this scope . It may be that I will rebuild this one as well......why not? It's not a very useful scope but it has survived 59-60 years and I think it is worth the attempt. I did notice that all the components and pots have some sort of white coating on them which, if I didn't know better, I'd think might be mildew but I don't smell the "mildew" odor. This bears some further investigation before I go too far.
Thanks again to all of you for your advice, suggestions and help keeping this scope novice in the game.
Mark
Last edited by retiredinprescott on Jun Wed 24, 2009 10:31 pm, edited 1 time in total.
PostPosted: Jun Sun 21, 2009 2:47 am
Your scope may have spent a long time in a damp place. Suggest you rig a way to warm it to around 120 degrees and let it sit there for several days, just to get any moisture out - before you attempt to apply power.
--Chuck
PostPosted: Jun Sun 21, 2009 2:51 am
Chuck,
Luckily I live in central Arizona these days. 10% humidity and tons of sunshine. I'll put the scope (minus the case) outside during the day for a couple of days. That should do it. My wife quickly vetoed the oven idea.
I also found a source for a 1000VDC oil capacitor (about 2uf) of the right size to replace the original one in the scope now.
That should get me started.
Mark
PostPosted: Jun Sun 21, 2009 5:09 am
Glad your back with it, the humidity in this area is like walk outside and your soaked.
Rodney
PostPosted: Jun Sun 21, 2009 7:30 am
Good for you! I have an O-11 I am gonna tinker with here sometime. It sorta works. Got a manual and stuff on the way for it!
Todd
PostPosted: Jun Sun 21, 2009 3:05 pm
Good to know that the CRO is now working.
Now that you have the book, sorting out the second one should be "a walk in the park".
I would follow the dryout idea. Pull the rectifiers & check the transformer. If it's all good..... go for it with the refit.
Clean it wearing a respirator as you don't know what the powder is; Even Mildew inhaled can be dangerous.
Marc
PostPosted: Jun Sun 21, 2009 10:56 pm
The white stuff is probably the cadmium plate going off - oxidation. The powder is nasty - the procedure I use is a stiff paintbrush and a vacuum cleaner nozzle close by - seal the bag and throw it in the garbage when you've finished. Don't tell the greenies or they'll have the Environmental Protection Agency around to have you taken away!
Cheers - Martin ZL2MC
PostPosted: Jun Mon 22, 2009 1:47 am
Nolan Lee had an innovative way to dry out transformers posted on his site, it you find moisture or other hard-to-explain problems remain after you've given the 'scope a good suntan. Seems like somebody here is hosting an archived copy of his site....
If you can't find that, and if you find your transformers won't dry out, I'll look for the Nolan Lee method, I may have printed it way back when. It was classic Nolan Lee, and very effective.
PostPosted: Jun Mon 22, 2009 4:21 am
Too bad the 5BP4 is weak; that tube will fit at least one early British TV. Maybe someone would do a swap for you with a 5BP1...
PostPosted: Jun Mon 22, 2009 4:26 am
The 5BP4 CRT is the best one I have. I am using it in the scope I rebuilt. I put the second best one (a 5BP1) in the second Heathkit 0-5 and I've started working on that scope. I replaced the electrolytic caps so far and checked the 1uf, 1000V oil filled cap. I can get a spot on the CRT but the sweep doesn't seem to work. I have yet to replace any of the paper caps and check all the resistors. That will be next.
Mark
PostPosted: Jun Wed 24, 2009 10:39 pm
I now have both Heathkit 0-5 scopes rebuilt and functioning OK.
The final problem I resolved was with five micamold 6800pf capacitors in each scope. I initially assumed they were mica capacitors and did not replace them.
There is a thread about these capacitors in the electrical/mechanical restoration forum entitled " Bad Micamold 6800pf capacitors?"
It turns out that ALL of these capacitors were bad in both scopes and when I disected one, it was a paper/foil capacitor in a square moulded case designed to look like a mica capacitor. Live and learn, I guess.
Anyway, changing out those capacitors (one in the sweep frequency switch and four across the four 6SH7 tubes between filament and cathode) didn't really change the way any of the CRTs I've described before behaved but the scopes are well behaved now and pretty stable. Good enough for a 1950 vintage, low end scope.
I'm happy with the outcome and thanks again for everyone's help.
Mark
 Post subject: Re: Heathkit 0-5 Oscilloscope(s)--FINALE
PostPosted: Feb Sat 03, 2018 1:03 am
Hello all,
Can someone share the Heathkit Model O-5 Oscilloscope schematics or manual?
I am trying to resurrect one so I will appreciate all the help you can provide.
Thanks for your time!
PostPosted: Feb Sat 03, 2018 7:58 am
Greetings to Mark and the Forum:
I have a couple of N.O.S. 5UP1's. I don't know if they will sub for the 5BP1 or not, but if so and you are interested, PM me.
Jim T.
KB6GM
PostPosted: Feb Sat 03, 2018 11:01 am
From personal experience with "Micamold" anything with Micamold on it should be treated with the same contempt as a Waxed Paper cap: "Micamold" on a cap, or resistor, is its brand and in many caps, is not to be confused with Mica: The mineral & dielectric.
Marc
Users browsing this forum: Majestic-12 [Bot] and 8 guests
