It is currently Feb Sat 23, 2019 1:42 pm
 Post subject: Hickok 533 (or A ) set up for 6CD7/ EM34
PostPosted: Jun Sun 22, 2003 11:02 pm
<BR> I have a 533 and 600 (not A models)<P> Only the 3 page foreign tube data for them.<P> I believe the "A" models have much more listed data for foreign tubes .<P> I realize the data is not compatible between models, but for merely testing the "eye" tube function, I suppose it would work.<P> Would someone help me with setup data for this type (EM34/6CD7) if it is listed in the "A" model info?<P> I can't locate a setup for this tube for a Jackson 648S (supplements,) or old Precision 910 (little wonder why,)- or I'd settle for this.<P> I had kept a restored Precision 10-12 around to test this type only, since it was the only tester here that listed the setup for that tube type (EM34).<P> It's gone now, given to someone that had a greater use for it, - (and more room in the shop.)<P> I'd appreciate info on this. <BR>$15 is a bit much for me to gamble on if I were to buy the "A" model data book, to use on an incompatible tester.- only for one purpose<P> If this fails (sigh,) I'll begin the task of extrapolating available info and attempt to create a setup for this tube.<P> If i'm forced to "go this route," I'll post the setup- if I'm lucky enough to create one.<P> Thanks,<P> Den<BR><P>------------------<BR>
PostPosted: Jun Mon 23, 2003 1:11 am
The set-up for the Hickok 533A:<P>"6.3 JR-4507-0 English 100 Press P5<P>Connect a 1 meg resistor from the plate jack to pin 3 of large 7 pin socket. Connect a second 1 meg resistor from plate jack to pin 6 of large 7 pin socket. Set micromhos switch on English position. Eye one closed at bias of about 30. Eye two closed at bias of about 55. Bias=Vary"<P><BR>For Jackson 648 Series:<P>"6.3 123 A45 21 XZ<P>6.3 123 AC58 36 XZ<P>6.3 123 6 0 WX<BR>Visual Test"<P>I don't have any experience testing this tube, and hope the data works out. I can't seem to type the Jackson data in so it lines up properly. On the last line the "6" goes under AC58 and the "0" goes with the WX.<BR> <P>------------------<BR>
PostPosted: Jun Mon 23, 2003 11:34 am
<BR> Thanks, Chris!<P> That info sure seems like it will work.<BR> <BR>I'll whip up an adapter w/ banana plug & the two resistors to another large 7 pin base, instead of fiddling with stabbing resistors into sockets.<BR> Other eye tube types must be tested in this manner (resistor) as well, on the Hickoks.<P> I guess their set up scheme wasn't as flexible as that of the humble Precision. - <IMG SRC="http://antiqueradios.com/forums/wink.gif"><P> Den<P>------------------<BR>
Users browsing this forum: Lou deGonzague, Vintage Collector and 12 guests
