It is currently Feb Tue 20, 2018 3:03 am
 Post subject: Eico 625 and 7 volt tubes.
PostPosted: Aug Mon 26, 2013 12:02 am
Does anyone have any info on testing 7 volt tubes with an Eico 625? My dad has a Philco Transitone that he wants to test the tubes from but his book does not list them. Thanks!
Consider me a straw in your haystack of success.
 Post subject: Re: Eico 625 and 7 volt tubes.
PostPosted: Aug Mon 26, 2013 12:07 am
Nominal filament voltage on "7 volt" tubes is 6.3 volts. ~Same as 6 volt tubes. Does the tester have a loctal socket for these tubes? If it does then the test data should be out there somewhere.
-Bill
Visit my homebrew page
www.sparkbench.com/homebrew/homebrew.html
PostPosted: Aug Mon 26, 2013 12:49 am
Do you have a roll chart?, they are listed there. Look at the second column.
PostPosted: Aug Mon 26, 2013 6:34 pm
Also remember that you can pretty much obtain/apply any filament voltage to a tube under test, even if that voltage is not provided as a choice on the tester's panel, simply by readjusting the tester's Line Reg potentiometer (the large wire-wound pot on the tester's lower left panel) to obtain the precise voltage you're after. Some Loctal tubes (the "7" and "14" series) are a bit difficult (I think) to know exactly which filament voltage should be applied to them, because some tube handbooks (Sylvania, for example) list a "nominal" filament voltage as high as 7 volts (or 14 volts for the 14 series), but in reality, they run best at no higher than 6.3V or 12.6V; and if run continuously at 7 or 14 volts, they will burn out much sooner. Remember that the term "nominal" is not necessarily the voltage you should run a tube at, especially for hours at a time.
Fred
PostPosted: Aug Tue 27, 2013 2:22 am
Thanks guys. I will finally get these tubes tested.
PostPosted: Aug Tue 27, 2013 3:48 pm
"7" and "14" series loctals are an exception to the rule that the first digit(s) of a tube number are the nominal heater voltage. The "7" and "14" were used to differentiate the loctal series from "6" and "12" which were used for octals. They are still 6.3-volt and 12.6-volt tubes, so you would set the heater voltage on your tube tester accordingly.
It is interesting to note that 1-volt loctals have "1L" numbers such as 1LC6, where the "L" is for loctal, but they did not follow this practice with the other voltages--perhaps because they were afraid they'd run out of numbers if they did!
Thomas A. Edison
Users browsing this forum: Willitwork and 9 guests
