It is currently Feb Sun 17, 2019 11:16 pm
Post New Topic Post Reply  [ 61 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Looking for a talking volt meter
PostPosted: Jan Sat 25, 2014 11:34 am
I am looking for a good talking multimeter. I have one from china and there is no button on the probe to announce the reading and it is a pain to use thanks.
 Post subject: Re: Looking for a talking volt meter
PostPosted: Jan Sat 25, 2014 11:54 am
I just found this site---they have a Protek talking multimeter:
http://www.captek.net/Captek/Talking_Calculator.html
(scroll down---it's right after the calculator)
-Mark http://pixellany.com
PostPosted: Jan Sat 25, 2014 2:50 pm
Does it scream if you overload it?
PostPosted: Jan Sat 25, 2014 7:59 pm
Timmy1 see The meter in your your last post viewtopic.php?f=8&t=176668
I used the NEXXTECH 221-8202 meter in the Fall 2013 session of the Kelly Creek Community School Electronics Program and it worked just fine.
An additional feature is a bright LED on the probe that lights up where you are taking the measurements
if you have some sight for this.
These meters are inexpensive, but the weak point is the button probe, so if find a used one, makes sure
the probes are not worn out. Thew meter has a clearer voice than the two older Microntas I have here.
If you can find a Radio Shack with any stock it might be wise to grab a few of them.
Are you still working on generator electrical systems ?
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jan Sun 26, 2014 3:39 am
I have a Micronta 22-164 talking meter and when I put new batteries it says change batteries nomater what setting the dial is set on so I figured it is a faulty part but not sure which part.
PostPosted: Jan Sun 26, 2014 3:55 am
First time I heard of a talking volt meter. I think it would drive me nuts. I tried to use a GPS once and had to turn the thing off.
Rod
Radio 1240, After the Fallout...Radio Free Chillicothe
PostPosted: Jan Sun 26, 2014 6:01 am
I have two 22-164 meters. One works fine. The other says change batteries despite being fed
the correct voltage to the PC board, independent of he batteries. Until Timmy1 mentioned it.
I haven't touched them in years, There seems to be no data from Radio Shack support for that
model.
There was something odd about the operation of the bad one and I will try and find out
, hopefully without destroying the good one too.
These talking meters only talk when you press thew probe button.
However, they may annoy others, working around you. Perhaps people know that.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Jan Sun 26, 2014 11:14 am
Steve that would be great if you find out what causes that problem.
PostPosted: Jan Mon 27, 2014 1:31 am
Some one told me it might be a bad internal memory battery in the meter.
PostPosted: Jan Mon 27, 2014 2:13 am
Might be a Radio Shack ploy to get you to buy more of their batteries.
PostPosted: Jan Wed 29, 2014 1:12 am
Are the battery terminals on your talking meter corroded or dirty; if so then cleaning them might help alleviate the problem.
PostPosted: Jan Wed 29, 2014 1:20 am
I made sure they were clean
PostPosted: Jan Thu 30, 2014 4:59 am
Does any one know where I can find more information on that meter?
PostPosted: Jan Thu 30, 2014 4:21 pm
It's possible that a component drifted out of tolerance (most likely a resistor). Perhaps steve can measure the values of the components in his voice meter that is experiencing the same problem.
PostPosted: Feb Sat 01, 2014 3:57 am
I had some one take a picture of the meter coponents maybe some one can see if something
looks burned
PostPosted: Feb Sat 01, 2014 5:14 am
The picture helps a little but it is not very clear. What is the large sky-blue part at the bottom center? A back-up battery perhaps?
I saw a nexxtek on ebay for $50 but I imagine you would rather fix this one.
Maybe one of us would take a look at it if you could ship it? I'm not too familiar with the design, but can spot a bad part as well as the next guy.
-Ed
PostPosted: Feb Sat 01, 2014 5:24 am
Ed I can't tell the blue part I am blind but I think you are referring to the rotary dial switch a square large part? there is no backup battery in it.
PostPosted: Feb Sat 01, 2014 5:49 am
It's just below the rotary switch. It just seems to be of a large size for typical parts in a multimeter. Might be a large capacitor, but I was guessing or hoping it might be a backup battery that failed. A relatively easy fix if so.
I actually didn't realize you have vision issues until I read one of your older posts about a capacitor meter back in 2011, referenced in one of your more recent threads.
I'd volunteer to look at it if you're able to mail it to me. I am used to not having any schematics or service info for things I tinker on. It may have a bad part that is no longer available, but it could also be something more easily repairable.
-Ed
PostPosted: Feb Sat 01, 2014 6:21 am
Thanks Ed that would be great. I know the part you are referring to now it looks like a resistor or capacitor. can you pm me your address thank you.
PostPosted: Feb Sat 01, 2014 7:41 am
Done! Hope I can help you out with it!
-Ed
Users browsing this forum: Al Green, Google Adsense [Bot] and 9 guests
