It is currently Jan Wed 16, 2019 8:15 pm
 Post subject: Superior Instruments TV-11 Tube Tester Restoration.
PostPosted: Oct Tue 06, 2015 4:08 am
Hi everyone! I recently acquired a Superior Instruments TV-11 last weekend. The wood on the case is slightly splintering and the lid is falling apart but the panel looks spotless. I haven't plugged it in due to the insulation flaking off the chord. I opened it up and I only found one capacitor that was across the meter. Presumably it is for low voltage. I was wondering if I should be concerned about it and get a replacement or if it is fine and I can hold off on a replacement. I am also not 100% sure how to operate so any operating instructions are welcome. Thanks again!
Did you try flipping the work/no work switch?
 Post subject: Re: Superior Instruments TV-11 Tube Tester Restoration.
PostPosted: Oct Tue 06, 2015 5:02 am
You can find the manual here.
http://bama.edebris.com/manuals/superior/tv11/
There are two capacitors .01 and .5 both of these need to be replaced. There should not be a capacitor across the meter. All the resistors should be checked and replaced as most of them will have drifted high.
PostPosted: Oct Wed 07, 2015 1:48 am
Thanks! What voltage are those capacitors rated for? I might have replacements on hand.
PostPosted: Oct Wed 07, 2015 2:25 am
250 volt or higher caps will be fine.
PostPosted: Oct Wed 07, 2015 4:24 am
Thanks! I don't think I have capacitors that will take the voltage.
PostPosted: Oct Fri 09, 2015 3:14 am
I have been looking through my capacitor pile and I found a 103k ceramic disk capacitor. It has a value of 0.01 MFD but I don't know the tolerance. Does anyone know if this will work? Also, what type of ceramic disk capacitor will replace the 0.5 MFD capacitor?
PostPosted: Oct Fri 09, 2015 6:54 pm
"k" is +/-10% tolerance.
PostPosted: Oct Sun 11, 2015 5:30 pm
I replaced both capacitors and the power chord! I found that the 40 kilo ohm resistor needs to be replaced. Does anyone know what wattage the original was rated for?
Users browsing this forum: Barry H Bennett, KB8PUH, MarkPalmer, Tube_Enthusiast and 9 guests
