It is currently Feb Wed 20, 2019 2:18 pm
 Post subject: OS-8/U Oscilloscope Circuit Diagram
PostPosted: Dec Fri 02, 2016 6:21 am
Hello guys,
I have a OS-8/U oscilloscope I'm trying to restore. After examining the inside I've come to find that the tubes it uses are different than those in the OS-8C/U which seems to be the only oscilloscope I can find the circuit diagram/manual for. I'm wondering if anyone has a picture of the circuit diagram for this particular model. I found a thread a while ago where someone had a similar question, but they seemed interested in the entire manual; I really only care about the diagram.
Luke
KF7WSP
 Post subject: Re: OS-8/U Oscilloscope Circuit Diagram
PostPosted: Dec Fri 02, 2016 12:08 pm
HI LUKE:
THERE ARE 3 VERSIONS HERE IF YOU HAVE NOT SEEN THIS.
http://bama.edebris.com/manuals/military/
HOPE THIS IS HELPFULL.
THERE ARE SEVERAL THREADS HERE ON ARF.USE THE SEARCH FEATURE
BEST 73
WALTER-W2WIQ
PostPosted: Dec Fri 02, 2016 11:51 pm
W2WIQ,
Thanks for the reply. The manual that says os8 is actually another copy of the one for the os-8c/u. I will use the search and report back if I find anything.
*Edit* I searched the forum to no avail. I found a few threads that mentioned the later schematics might be similar enough, but they don't seem similar at all. The os-8/u has just seven tubes excluding the CRT, and after tracing some of the wires I've concluded that the x and y amplifiers are single-ended (the later models all seemed to use push-pull arrangements). Also, one of the tubes is a 12AU7, which seems like a poor choice to use unless you wanted to get high gain at a low frequency (I suspect it might not be the original tube). The only other dual-triodes in the machine are a 12AT7 and a 6J6, the rest are pentodes, so I'm thinking it might lack a sync amp or an attenuator section.
Luke
KF7WSP
PostPosted: Dec Sat 03, 2016 3:21 am
I have an OS-8/U manual. The tubes shown on the schematic are -
12AX7
12AT7
6AK6
6AK6
6AG5
6J6
6X7
If you PM your email address, I will try to get the schematic scanned this weekend and sent it to you.
Bob
Everyone is ignorant...
only on different subjects.
PostPosted: Dec Sun 04, 2016 9:51 pm
radious,
PM sent.
Luke
KF7WSP
PostPosted: Dec Wed 07, 2016 9:21 pm
For anyone that is interested, I have created an abbreviated version of the OS-8/U manual which should be useful to anyone trying to work on one of these scopes.
It can be downloaded here - http://www.filedropper.com/os-8umanualabbreviated
Bob
PostPosted: Dec Thu 08, 2016 3:38 am
Bob, Thank you very much for taking the time to scan and post this, and making it available to everyone.
PostPosted: Feb Tue 06, 2018 6:03 am
Hello
I just came across an OS-8 and could use some troubleshooting help.
It powered up OK, but it blows both line fuses. Might this be the due to bad electrolytic capacitors?
Richard
AE6XO
PostPosted: Feb Fri 15, 2019 3:04 am
Why did you put it up on a site that you have to join and pay for.
Why not a free one?
PostPosted: Feb Fri 15, 2019 3:51 am
Thanks for your reply. I am not aware that I have to pay for participating in the Antique Radios site.
I installed new capacitors in the OS-8 and got it working.
Richard
PostPosted: Feb Fri 15, 2019 4:03 am
Richard
You do not have to pay to use ARF although you can donate. The comment about paying was referring to the site that is (or was) hosting the schematic. Be aware that that thread is over two years old.
Glad you got it fixed.
Jim Mueller
PostPosted: Feb Fri 15, 2019 4:31 am
Thanks.
Richard
Users browsing this forum: pelud and 7 guests
