It is currently Jan Sun 20, 2019 10:17 pm
 Post subject: Removing moldy smell
PostPosted: Dec Mon 04, 2017 12:21 am
I recently picked up this Superior Instruments TW-11 tube tester:
It's obviously sat around in a moist environment for quite awhile. After removing it from the case I found a fair amount of mold inside on the bottom of the case, and front panel itself smells badly of mold. I've cleaned it up and it looks quite nice, but still smells. I'm pretty sure I'm going to toss the case and build some sort of an enclosure for it, but how can I remove this smell without damaging any of the electronics?
I do want to make this a nice unit. Both slide switches are shot, although I think I can fix at least one of them. But I found a guy online that has one of these for parts and is willing to send me the switches out of it. Very cool! I connected the wires from the switches to simulate it being powered on in the 'HI' power mode, and in the 'QUAL' mode. I connected it to the variac and brought it up slowly. It was drawing less than 10mA so I set the switches and controls for a 12SA7 and tested it...it worked!
Thanks!
 Post subject: Re: Removing moldy smell
PostPosted: Dec Mon 04, 2017 12:24 am
What is the case made of? If it's metal you can paint it and if it's wood you can use spray lacquer (inside and out).
PostPosted: Dec Mon 04, 2017 3:27 am
I've had some success dealing with mold issues:
I've been successful addressing this by washing/wiping/tooth-brushing and otherwise sponging down with dilute household vinegar/water, then PineSol/water then a dilute water/bleach solution to rinse. Next - I put them out in the direct summer sunlight for 1/2 a day, turning occasionally, to heat them up/dry them out. Seems to work well. Once done, I have not seen return of any mold. Even when not stored in ideal dry conditions.
Your tube tester case might respond to that kind of treatment too (however you will need to find some way to remove the electronics/panel).
Good luck,
Grid2
PostPosted: Dec Mon 04, 2017 3:31 am
Neat White distilled vinegar will kill most mold and mildew spores and the vinegar smell quickly disappears.
Contrary to popular belief, they feed on bleach and water even though it seems to do a good surface clean up job initially.
Baking soda, charcoal or cat-litter will absorb odors (seal in a plastic bag for a few days).
Dryer-sheets will make old musty books smell pretty (again, seal in a plastic bag/container) if you can tolerate the perfume smell. Lol
Edit: image updated.
PostPosted: Dec Mon 04, 2017 4:03 pm
Thanks guys! I'm really not too concerned about the case itself...it's not in very good shape and I think I will end up trashing it and building something out of wood, or maybe see if I can make something on my 3D printer. I think this one is made of some thick cardboard and covered with vinyl.
What I'm trying to freshen up is the front panel itself. I've removed it from the case and cleaned it up. The front cleaned up quite well and it looks nice. But it still stinks, even out of the case. How can I freshen it up without risking damage to the electronics?
Thanks!
PostPosted: Dec Mon 04, 2017 4:30 pm
The Sun. When we used to open "War Stock" material that was held in Quonset huts for years, we'd get that funk/mildew smell. We'd disassemble the items, and lay them in the sun for 8 hours or so. UV light was the agent, I guess.
For wood crates, we sprayed them inside with Shellac - it sealed the wood and the smells both.
Same for fire damage - after soot removal, the restoration folks sprayed the walls with shellac and repainted. No smell, no evidence of fire...
Brian
PostPosted: Dec Mon 04, 2017 6:03 pm
Thanks Brian - no sun today so I'll wait for a sunny day and let it bake!
PostPosted: Dec Tue 05, 2017 1:16 am
+2 on the sun. If you want to take a bit of a more radical approach, remove the meter movement, and anything else that looks like a soaking would damage it... then soap and water, spray with lysol, rinse, soap and water again, THEN sit in the hot sun for a few hours. Or a convection oven with the door open, at maybe 110 degrees or so.
Then just clean/lube the switches as you normally would. Works like a champ. I use a garden hose most of the time but a gentle brush works too ... just don't be too violent. Maybe try this on some instrument you don't care about.
The key is DRYING .. you have to bake all trace of water out of everything. And then a q tip with some deoxit or other contact cleaner sparingly on the wafer switch contacts, possibly a dab of some non migrating grease on the switch detents .. stuff like that.
Pure vinegar, btw, is great for cleaning the front panel in most cases although make sure it won't dissolve something and don't leave it on there very long. Gentle wiping is usually plenty.
www.bbtvtestequipment.com
PostPosted: Dec Tue 05, 2017 3:45 pm
Thanks Brian - great tips! I'd be concerned about the power transformer primarily, and would be hesitant to remove it given the number of wires involved. It's cold today (upper 20s, going to lower 30s) but the sun is out bright so it's sitting in the sun right now. I'll let it sit until late afternoon when the sun is going down and see how it goes.
PostPosted: Dec Tue 05, 2017 3:48 pm
The power transformer can get wet and dry without consequence as long as it is baked dry immediately. That doesn't mean you have to drown the poor thing :) use only as much water as necessary
PostPosted: Dec Tue 05, 2017 4:19 pm
Sorry Barry - my previous 'Thanks' was meant for you...got my 'B' names mixed up lol. Anyway, thanks for the great info. I'll see how the sun does...I'll probably try 2 or 3 doses if the first doesn't work. If it still stinks after that I'll try more drastic measures.
PostPosted: Dec Tue 05, 2017 8:46 pm
no prob and you're welcome. be advised though .... "in the sun" means in the sun on a HOT day. 30s 40's 50's etc are not going to dry anything. It would need to be a hot summer day.
I'd opt for the oven method in this case. 100 degrees or so, maybe 110 with air circulating for several hours at least. No hotter than that though.
PostPosted: Dec Wed 06, 2017 12:13 am
For the fake leather, white vinegar and water in a spray bottle. a small nail cleaning (small scrub) brush or tooth brush work well.
For wood Murphy's oil soap. Been cleaning a bunch things in the radio shed.
Not sure why but 2 things can be next each other one look like a mold spore farm and the other has none? Has to be what was used on the case years ago.
pics here https://www.facebook.com/oldgoaly/photo ... 1507215179
Users browsing this forum: Exabot [Bot] and 13 guests
