It is currently Feb Sun 17, 2019 10:50 pm
Post New Topic Post Reply  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Clamp On Ammeter Hot/Neutral Accuracy Difference ?
PostPosted: Feb Mon 05, 2018 5:57 pm
We're talking about the current in the hot and neutral lines to a single appliance.
The "neutral" current is only related to current in the service neutral by name.
Whether the service neutral current is zero or 100 amps, the current induced in the appliance neutral will be zero.
What we are talking about are the instructions that came with a piece of test equipment which state that better accuracy can be obtained off the hot side of a line than the neutral, and anecdotal evidence that this is true. Many of the newer digital clamp meters are more sensitive to higher frequency harmonics than the old analog meters were. Therefore, if that sort of thing is going on in the power system, it is possible that the meter accuracy could be better on the hot side of the line than on the neutral.
If the power is clean, there is no leakage, and the wires are separated far enough that there are no magnetic interactions between them, then of course the amps in have to be equal to the amps out and the meter should indicate accordingly.
Thomas A. Edison
PostPosted: Feb Mon 05, 2018 9:21 pm
Within the scope of a radio, or music amplifier, your protection lies in
the limited ampacity of a 18 gauge power cord.
When neutral and hot are being discussed in terms of home or commercial
service equipment, simply keep away. There is just too much danger.
A humble range breaker might light off a 10,000 amp minor sun inside
the panel, or even the wall plug, if a current measurement goes sideways.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Feb Mon 05, 2018 9:35 pm
Most of us don't run our 120 volt branch circuits off a 50 amp breaker. Most of mine are 15 amp except for a few specialized 20 amp circuits.
Users browsing this forum: richfair and 15 guests
