It is currently Jan Fri 18, 2019 3:04 pm
 Post subject: Tube Rejuvenator
PostPosted: Feb Mon 05, 2018 1:14 am
EUREKA!!! The last tube tester you will ever need!! Bring on the pile of 6L6, 12AX7, and 6SN7 tubes. Hey, it doesn't say it can't handle them ;-)
www.bbtvtestequipment.com
 Post subject: Re: Tube Rejuvenator
PostPosted: Feb Mon 05, 2018 1:20 am
Anyone into 20's battery sets AND keeps them alive could certainly use one of the Jefferson Tube Rejuvenators.
I have one...
"Gandhi"
PostPosted: Feb Mon 05, 2018 1:30 am
I have one...
I figured someone would :) Some cold and snowy evening I may restore it, at least cosmetically. Finally got a moment to weed through my spreadsheet ... re-discovered this little critter
PostPosted: Feb Mon 05, 2018 1:35 am
Barry H Bennett wrote:
I have one...
There is practically nothing inside, transformer, connections, it should work O.K.
"Gandhi"
PostPosted: Feb Mon 05, 2018 2:00 am
I sold one here on ARF a few years ago that I had used to rejuvenate several tubes and it worked fine without me having to tamper with it. It's a good little device and as Chas stated, it probably needs nothing done to it. It just "cooks" the filament to bring Thorium to the surface.
Users browsing this forum: Bugman, Exabot [Bot] and 12 guests
