It is currently Feb Wed 20, 2019 2:16 pm
 Post subject: tube pcl800
PostPosted: Feb Fri 09, 2018 11:26 am
Hello! I need to try a PCL800 tube on a hickok 547A tubetester, does anyone have a way to do it?
 Post subject: Re: tube pcl800
PostPosted: May Tue 01, 2018 4:56 pm
Hello Frank, the PCL800, which is the same as the 30PL13 can be tested on a hickok 547 as follows: Pentode section; FIL. 16 volts. EV3672-0 --Bias 25 --English 88- should give you 4,300 GM .---- Triode section: EV1908-0 - Bias 12 - English 14 - should give you about 2000 GM.Then you tell me how I went, Greetings
Users browsing this forum: Al Green, pelud and 6 guests
