It is currently Jun Mon 25, 2018 9:22 am
Post New Topic Post Reply  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Heathkit VTVM V-6
PostPosted: Feb Tue 27, 2018 7:23 pm
Greetings forum and Mikekent,
This is off topic but---Did Gary Clark pass away?? I know he's not on eBay anymore. I too have been restoring VTVMs---He was the best I've seen so far. really liked the battery elimination circuit.
Jim
PostPosted: Feb Tue 27, 2018 8:03 pm
Can you post a pic of the 2 KV cap? If it's a mylar type then no need to replace it.
PostPosted: Feb Wed 28, 2018 12:08 am
I'd suggest using a Switchcraft 1/4" phone plug for the DC test cable instead of one of the newer Asian versions with the black plastic insulator. The Switchcraft plugs have what appears to be a fiberglas insulator at the tip; I suspect it would be safer at higher voltages.
PostPosted: Feb Wed 28, 2018 4:15 am
The phone plugs that came with these meters had an insulating band at the tip that was much wider than the one in a standard audio plug. I don't if there was a special name for these?
RRM
PostPosted: Mar Tue 06, 2018 7:41 am
Greetings to RRM and the Forum:
RRM writes:
You are quite correct.... I have one of these plugs.... but I doubt that they are available any more. It might be possible to disassemble a stereo plug and replace the ring connector with an insulator.... but for low voltages, I don't think it would be worth the trouble.
BTW, here is a photo of my uni-probe prototype. The slot for the switch actuator is larger than I wanted it; I will have to build some jigs to make it smaller and neater. I ran out of tape for my Dymo label-making machine, so only one switch function is labeled. I tested it when complete with my Biddle megger and it withstands 500 volts. The switch frame and the screws are grounded.
Also, I remember someone posting a photo of the probe tip mechanism that I used here along with where it could be bought. However, I cannot now find it. Does anyone know where these can be purchased? I struck out on Digikey, and I have a very limited supply in my junk box.
Jim T.
KB6GM
PostPosted: Mar Tue 06, 2018 5:02 pm
It's from here:
viewtopic.php?p=2816203#p2816203
These HH Smith probe tips can be had from Electronics Goldmine, although quantity is probably limited there too:
http://www.goldmine-elec-products.com/p ... ber=G21843
PostPosted: Mar Tue 06, 2018 7:17 pm
Greetings to Steve and the Forum:
Thanks Steve. That is the photo I remembered. Unfortunately, upon going to the site and examining the description, I find that one must solder the connection on the back. This would make assembly of my uni-probe problematic.
I need the style where the lead goes through from the back, extends through an angled hole, wraps around and is then secured by threading on a collar with a cone-shaped bore over the tip.
Any leads on where these might be found?
Jim T.
KB6GM
PostPosted: Mar Wed 07, 2018 12:03 am
jThorusen,
Try this guy. I buy all my meter supplies from him.
http://stores.ebay.com/KK4HXJ?_trksid=p2047675.l2563
Jim
PostPosted: Mar Wed 07, 2018 1:27 am
The part you are looking for is HH Smith model 200
Part is discontinued, some available on ebay. I have sent you a pm re: my limited stock.
-Chuck K7MCG
PostPosted: Mar Sat 10, 2018 2:19 pm
To an earlier poster, yes, Gary Clark passed away. Gary built Siamese probes for his meters using standard 1/4" mono plugs and originally encouraged me to make and offer the kits and probes that I sell on eBay. I treasure the emails and information he provided, my collection of his VTVM and electronics books and my IM-28 that he modified. He was a great talent.
Mike Kent
KK4HXJ
Realistic DX-100/120/150/150a/150b/160/200/300/302/394 Radios
VTVM's & Test gear
Users browsing this forum: Pbpix and 9 guests
