It is currently Dec Thu 13, 2018 12:00 pm
 Post subject: My all new isolation trans./variac
PostPosted: Feb Mon 26, 2018 4:05 pm
I present to you my latest creation - the Isovac 3000B. It's an isolation transformer and variac all in one (hence the name Isovac). Model number 3000, just because, and B because it's replacement for the original Isovac 3000 that I made about 10 years ago. I had a couple improvements in mind, and turns out it was better to just start from scratch. And I know that there was a fierce debate over whether or not to ground the output. I'm with the crowd that says no, so it does have a 3 prong outlet, but the ground slot is not connected. But that way I can still work on amps that have a 3 prong cord.
I am going to change out the voltage scale since it's only to 120, not 130.
Michael
 Post subject: Re: My all new isolation trans./variac
PostPosted: Feb Mon 26, 2018 5:37 pm
Nice!!---what is the case?
-Mark http://pixellany.com
PostPosted: Feb Mon 26, 2018 7:12 pm
Hi Michael,
Congratulations! That is a very nice piece of work. 8)
I am in full agreement with you on your decision not to ground the outlet. By no means should this be done if this also serves as an isolation transformer. But using the 3-prong receptacle (equipment ground slot not connected) permits convenient connection of any gear, no matter whether it has a 2-prong or a 3-prong line cord. I have exactly the same setup on my own custom enclosure. [Although I will be the first to admit that mine does not have nearly the professional-looking appearance as yours.]
Poston
PostPosted: Feb Mon 26, 2018 7:51 pm
I have to disagree with Poston Drake . If your were to purchase a new Stand alone Isolation transformer, it would be equipped with a Three wire Power cord. The ground wire would pass through and be there for a Safety Ground. If your working on an All American Five, which would have a Two Prong Power Cord there would be no connection to the Safety Ground. But if you were to work on something that has a three wire power cord the isolation transformer would work just the same. But is something was to short to Chassis / Earth gourd the current would be bleed of and any safety ( fuse or Breaker) work trip. The ground wire is there for a reason.
PostPosted: Feb Mon 26, 2018 9:12 pm
Not always. You are looking at one that didn't. It came from Jameco, and I took the transformer case apart to remove the line cord (which is two pronged and was reused here), as well as the outlet, which was also two pronged.
What you have to keep in mind is that ground is an alternative path for the neutral line. But this is an isolation transformer. Current flows out of one side of the transformer secondary, through the device then back to the other secondary lead. An alternate path back to the line side would not complete any alternate path. So if you were in any way grounded and touch a hot lead in the device, it won't shock you because there is no complete circuit path.
Michael
PostPosted: Feb Mon 26, 2018 9:14 pm
This isn't the same size, but one like this: https://www.amazon.com/uxcell-Metal-Enclosure-Project-Junction/dp/B00LGJ2SEU/ref=sr_1_17?ie=UTF8&qid=1519676031&sr=8-17&keywords=project+enclosure
I then painted it black and off white. I have to say that overall it isn't bad, but I'm not impressed with the tiny screws that hold the front and back panels on. There really isn't enough grab for my liking. A trip to Lowes is in the future on that point.
Michael
PostPosted: Feb Mon 26, 2018 10:14 pm
Nice job, Michael.
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Feb Tue 27, 2018 9:41 pm
I like it! And since you can never get too many kudos... nice job!
PostPosted: Mar Sat 03, 2018 3:17 am
Looks great and practical too.
My home brew projects almost always looked kluged together because I am always in a hurry when
I am building them. One of these days I m going to take my time and build a nice one.
Knowledge is useless unless you can share it. KA5OBI
PostPosted: Mar Sat 03, 2018 12:41 pm
Impressive, nicely done, good looking cabinet choice, and great graphics. You've got my vote.
Nice to see you leave ground where it belongs, on the other side of the transformer. Yes, real two wire isolation transformers are still sold, but you have to look a little to find them, amongst all the modern "noise isolaters".
PostPosted: Mar Tue 06, 2018 3:54 am
Beautiful work sir!
I have a couple BK Precision 1655 and was looking at the schematics they have all sockets at Isolation, soldering Iron output, and input chassis grounded. Is this BK a different animal entirely?
PostPosted: Mar Tue 06, 2018 8:22 am
Not really. The BK just has more bells and whistles.
Michael
PostPosted: Mar Tue 06, 2018 10:14 am
Looks very nice.
No voltmeter? ...only amps?
PostPosted: Mar Tue 06, 2018 10:27 pm
Looks very nice.
I tried, but finding a matching set of volt and ammeters is like pulling teeth, especially ones that would fit on the panel.
I did find a pair of digital ones but there were lots of bad reviews on them. They'd just stop working, or the accuracy would just stray off.
Michael
