It is currently Jan Sat 19, 2019 6:00 pm
 Post subject: My New Flux Dispenser
PostPosted: Nov Thu 15, 2018 6:05 am
Accidents are the mother of all invention <?> I burned a hole in this flux tub months ago, inserted a toothpick and have been using it as dispenser ever since. I'm sure a cleaner job could be done with a drill but accidents will happen! If it had a flat bottom it would be perfect.
The Green Man says: He who has smelled the smoke is never again free.
 Post subject: Re: My New Flux Dispenser
PostPosted: Nov Thu 15, 2018 6:16 am
I like it! I have a the same can of flux and it has always had a splinter of a posicle stick stuck in with the lid propped up by it. And it has been a pain and dropped and made messes. I'm gonna drill a hole in mine tomorrow. And I may even upgrade to a tooth pick!
Thanks for the idea.
PostPosted: Nov Thu 15, 2018 3:40 pm
Good job!
I use liquid flux in a small glass vial with the glass dropper. Knocked it over on the bench countless times :roll: Spend another hour wiping, cleaning, tools with alcohol.
Next time I have the hole-saw out I'm going to bore a hole in a wood block so I can't tip the thing over :wink:
"Gandhi"
PostPosted: Nov Thu 15, 2018 6:03 pm
I never use the original plastic container, I transfer gobs of flux to a metal cup and work from the cup.
There's even blobs of solder mixed in with it, good for tinning the ends of wires. Nothing goes to waste.
Rocco
PostPosted: Nov Thu 15, 2018 6:15 pm
Baby feeding syringe aka oral syringe. Fill with a wooden Popsicle stick. Pennies from any pharmacy.
Users browsing this forum: Exabot [Bot], Microtouch and 8 guests
