It is currently Feb Thu 22, 2018 12:05 am
 Post subject: RCA VV4-3--C-11626
PostPosted: Oct Thu 12, 2017 11:05 pm
I am hoping someone can help me get this back together. My friend got this from a relative and its all apart in a box with missing pieces.I am hoping someone has pictures or a video of one. It is eletric motor , missing head for needle . This is what parts I have for the arm.
 Post subject: Re: RCA VV4-3--C-11626
PostPosted: Oct Thu 12, 2017 11:40 pm
Don't know much about them, I saw one here at an antique shop not long ago.
Yup, You're missing the reproducer assembly that holds the needle.
https://www.youtube.com/watch?v=ml5u7AU42oo
Rocco
PostPosted: Oct Fri 13, 2017 2:18 am
Somemore pictures of what I got
PostPosted: Oct Sat 14, 2017 1:31 am
http://www.victor-victrola.com is the place to start. Is 11626 the serial number on the name plate? It might be "VV 4-3 11626".
"There Is Nothing Finer Than A Stromberg-Carlson"
PostPosted: Oct Sun 22, 2017 7:48 pm
Hoping someone can help me get this eletric motor running.This has wires that come of motor and I am wondering
PostPosted: Oct Fri 27, 2017 6:17 pm
Hope someone can put me in touch with someone who can give me info as how to hook up this eletric motor. I am not sure if some part is missinga part.I have 2 wires hanging of motor a switch under turn table that has a plug on it which needs hooked up(to what) I have talked to a couple of phonograph repair men but they don't know about eletric motor ones. Thanks for any help.
Bruce
PostPosted: Oct Fri 27, 2017 6:51 pm
Looks like you are missing the receptacle to connect to the switch assembly. It seems from the pics that the two motor leads with ring terminals connect to the missing receptacle, which then connects them to the switch. It looks like there is an AC plug on the motor wiring harness that probably plugs into an outlet in the cabinet that has an AC cord on it.
Not sure the AC motor is original on this. I have always thought that model numbers beginning with VV mean a spring motor, and electric models start with VE. But I believe that is the type of AC motor that the VE models used.
-David
PostPosted: Oct Fri 27, 2017 7:39 pm
Hi Dave
I have a weird cable also but have no idea how wires would hook up .The cabinet does not have hole in it like the wined up ones have. Here is the cable.
Post New Topic Post Reply  [ 8 posts ]  Moderator: Alan Voorhees
Users browsing this forum: dberman51 and 6 guests
