It is currently Jan Sat 19, 2019 5:24 pm
 Post subject: RCA Radiola 67 Phonograph
PostPosted: Dec Fri 22, 2017 12:52 am
Looking for the electric induction disc motor governor for this set, along with the two small bearing balls that mount on both ends of the governor.
Or, if you know the diameter of the bearing balls, that will be a big help also.
The same motor was used on the Radiola 47, and probably other late 20's Victor models with electric phonograph motors.
Any leads will be appreciated.
Dan
 Post subject: Re: RCA Radiola 67 Phonograph
PostPosted: Dec Sun 31, 2017 3:48 pm
Bumping.
PostPosted: Dec Sun 31, 2017 8:53 pm
Any chance the governor is the same as on the spring motors? If so they are easily available.
-David
PostPosted: Dec Sun 31, 2017 9:34 pm
David:
This one's about 3 3/4" long. How long are the Spring motor governors?
Thanks. Dan
PostPosted: Jan Thu 11, 2018 1:49 am
Bumping. I need only the governor shaft. I't 3 3/4 " long. I have the rest of the governor; need the shaft to replace one with a broken end. Thanks. Dan
PostPosted: Jan Thu 11, 2018 11:58 pm
I checked the governor shaft on my VV-XI with common 2-spring motor. It's hard to gauge the length since it's not clear how much of the shaft projects into the bearing cups on each end. The distance between the two bearing cups is about 3 7/16", so an overall length of 3 3/4" might be about right.
-David
PostPosted: Jan Fri 12, 2018 1:27 am
Thanks David. You know who may have one of these? Dan
PostPosted: Jan Thu 18, 2018 7:22 pm
Try these guys:
https://www.victrolarepairservice.com/
I don't know if they deal with the electric motors or not, but they will know everything about the governors on the spring motors.
Here is a photo of the governor on my VV-XI:
-David
PostPosted: Jan Thu 25, 2018 3:25 pm
This is the governor shaft I need. About 3.68" if it still had the broken pin. No hole drilled thru the shaft. David, Does yours have a hole drilled thru it? Anyone have one of these?
Dan
PostPosted: Jan Thu 25, 2018 5:51 pm
I don't see the hole in the shaft in your picture, and I don't know if there is a hole in the VV-XI governor shaft or not. But it appears that the worm gears are very different.
Just call up the victrolarepairservice.com folks, they may be able to help you. They are very nice to deal with.
-David
PostPosted: Feb Sun 04, 2018 4:47 pm
Hey David, thanks. Sent my broken governor to Ray at Victrola Repair service and he found the right shaft for it. Meanwhile, saw one on ebay that looked right but assembled backwards. Bought it also, reassembled it the right way, so now I have two! Dan
PostPosted: Feb Sun 04, 2018 8:36 pm
Dan, so glad you got this sorted out!
-David
Post New Topic Post Reply  [ 12 posts ]  Moderator: Alan Voorhees
