It is currently Jun Wed 20, 2018 8:26 pm
 Post subject: Repair to a Magnavox model 1RP622
PostPosted: Jan Mon 08, 2018 2:26 am
I have a Magnavox model 1RP622 run 1. The first thing I am looking for is a needle for the record player. Any suggestion for a website to find one. I don't have a local store to go and get one.
2. The arm moves into position however the base where the record goes does not spin. I looked for a solution to repair for as where I might find parts, or what I might need to check.
Here is some extra information to help to answer these question above.
watts = 60cy
When ordering part look for Model 117V
UPDATE: the top concern now seems to be the system rejects and turns off before the needle arm drops. (arm travels half way, does not drop, and then return and turns off).
Last edited by OldfixNewthings on Feb Sat 17, 2018 11:48 pm, edited 1 time in total.
 Post subject: Re: Repair to a Magnavox model 1RP622
PostPosted: Jan Mon 08, 2018 3:11 am
Gary at VM Enthusiasts is a good source for record player needles and parts. The number you gave must be a model number. You need numbers off the various chassis and the changer itself in order to find service information and parts. You likely need to have the changer serviced before it will operate correctly again. There is a good chance the drive tire has become hard and slick and will not pull the platter thru the change cycle. They all do this after 50 or 60 years. Good luck
Always be yourself. Everybody else is already taken.
PostPosted: Jan Mon 08, 2018 3:28 am
The first thing first. You need to verify cartridge number but if original one you need a 365-DS73 for all speeds. But why buy one until you can determine if changer will work? You can google record changer repair and get what is involved, something simple maybe or something bad.
Bill J.
PostPosted: Jan Mon 08, 2018 4:01 am
Let us know what level of knowledge you have about your
record player, and if you understand our references and terms.
Record Changer Parts: (website for Voice of Music (V-M) :
http://thevoiceofmusic.com/
Hotwax
PostPosted: Feb Sat 17, 2018 11:47 pm
Users browsing this forum: Bob Bell and 8 guests
