It is currently Feb Fri 22, 2019 7:38 am
 Post subject: Converting a business phonograph?
PostPosted: Jan Mon 15, 2018 12:44 am
I have a model D Edison business phonograph. I would like to modify it to play 4 minute cylinders. It plays great, but is built for 150 tracks/inch, whereas a 4 minute cylinder is 200 tracks/inch. Anyway to change out the feed screw? Thanks,
I sell old radios at a loss. But I make up for it with quantity.
 Post subject: Re: Converting a business phonograph?
PostPosted: Jan Mon 15, 2018 6:27 pm
A feedscrew of the type you describe is unknown to me. However, another way to go is to reduce the speed of the feed screw through a gear reduction system. Numerous gear combinations are available through Boston Gear, Pic, McMaster Karr and others. Good luck with this project, Russie
PostPosted: Jan Tue 23, 2018 1:02 pm
Location: Gold Country, (Stanislaus National Forest) California 95235
I just paid to have mine turned by a machinist on a lathe.
2 kinds of men/tape. Low Noise/Wide Range.
LN=kind. WR=abrasive. Engineers=same thing.
PostPosted: Jan Tue 23, 2018 11:26 pm
If you don't mind me asking, what is the charge? Thanks,
PostPosted: Jan Wed 24, 2018 3:49 am
It was a long time ago (several years) and I think the going wage for a machinist back then was around $40/hr - so - maybe $70 including buying the block of aluminum and the engraving tool since those are a per-use deal.
Probably going to be a little higher than that anymore - and then you have to make sure your machinist gets the mount right (I had to diddle with mine a little bit).
