It is currently Feb Fri 22, 2019 12:08 pm
 Post subject: Philco M-24 Phonograph Parts
PostPosted: Jan Thu 18, 2018 4:07 am
I have a Philco B1350 table top radio/phonograph. The phono is an M-24 All Speed Automatic Record Changer. The idler drive wheel needs to be re-rubbered and it looks like the LP belt is broken. I also need a very small steel washer that holds a spring down just to the right of the idler wheel that is approx .396" OD and .205" ID and a fiber washer approx the same size for under the idler wheel. I do not have the service manual PR-2178 to properly identify these washers. Does anyone know where to acquire a good idler drive wheel or have mine rebuilt, the steel and fibers washers and a copy of the service manual for this M-24 Phonograph listed as PR-2178. Feel free to contact me at 651-248-2541 or hilan56@yahoo.com. Thanks for any and all help.
Charles
 Post subject: Re: Philco M-24 Phonograph Parts
PostPosted: Jan Thu 18, 2018 7:56 pm
http://www.thevoiceofmusic.com/
https://antiqueradioschematics.org/philco.htm
Contact Gary at Voice of Music for the M-24 parts. For the M-24 Service Manual, you could order a PDF one from (Steve Johnson) antiqueradioschematics.org/philco.htm if need be.
PostPosted: Jan Thu 18, 2018 8:19 pm
You can find the service lit in Beitman's Vol. 13, 1953 pp. 89-94.
https://www.radiomuseum.org/r/philco_m_24m2.html
There are free downloads for Beitman's if you do an internet
search.
Hotwax
PostPosted: Jan Thu 18, 2018 11:17 pm
Thanks for the info guys I will try both sites. The speed selector on the phono is really tight and I am having a devil of a time loosening it up. I am using liquid wrench and PB Blaster with very limited success so far. Any suggestions would be appreciated.
Charles
Post New Topic Post Reply  [ 4 posts ]  Moderator: Alan Voorhees
