Page 1 of 1
[ 8 posts ] |
Author |
cflusflwfl
Post subject: RCA 45 rp190 stops mid cycle Posted: Jan Fri 19, 2018 3:55 am |
I am trying my hand at repairing a RCA 45 player with the rp190 changer. It has a new cam and idler. The problem is that when cycling it stops mid cycle. I give the platter a very slight nudge and it continues to cycle on its own.
Top |
Tbirdkid
Post subject: Re: RCA 45 rp190 stops mid cycle Posted: Jan Fri 19, 2018 4:12 pm |
Joined: Aug Sun 23, 2015 6:01 pm Posts: 873 Location: South Jersey East of Philly
Assuming the idler and cam were resurfaced properly and no oil/dirt is on any surface--First--You may have weak contact of the idler to the platter/drive shaft. You can check that by grabbing the platter spindle while it is running, and see how much it 'fights' you when you try to stop the platter from turning...If you only have to lightly grab it to stop the platter turning, that lack of tension may be the problem. The spring that pulls the idler wheel to the drive shaft may need a 'tweak' to increase tension, but don't go too far with that. Also, the idler wheel may not be lining up vertically flush to the drive shaft, and you lose some drive power there. You can eyeball that and bend the idler wheel gingerly to get a good surface to surface mating...Second--Assuming you don't have issues in the spindle top mechanics----You may have to adjust the bracket that sets the 'distance' the changer cam sits from the splined piece in the platter shaft (sorry I forget the part name) the cam rides on. You may not be getting enough contact there to overcome the mechanical resistance of the changer mechanics. This also sets the rest point for the cycle cam so it doesn't keep cycling...The rest spot is the area in the cycle cam that has the recess. You have to do a kind of balancing act there so the cam comes to rest without going into the reject cycle all the time. It's hard to explain this stuff...but I've worked on tons of these players and just do it automatically when repairing. So if you're confused, keep asking stuff.
Top |
Robert Caston
Post subject: Re: RCA 45 rp190 stops mid cycle Posted: Jan Fri 19, 2018 4:28 pm |
Joined: Mar Wed 18, 2009 10:22 pm Posts: 207 Location: Houston, Texas
Did you do a complete tear down/clean/lubrication on the changer? If not, you are probably encountering lack of grip between the cycle cam tire and the knurled roller it engages during the change cycle. The teeth on the roller need to be totally free of any debris or oil to grip well. I recommend you remove the turntable, clean all drive surfaces (motor shaft, both idler tires, inner turntable rim, cam tire and the knurled roller) with isopropyl alcohol. Once all of those parts are absolutely clean, your changer should work fine. If not, then refer to the above comments regarding spring tension, alignment, etc.
Top |
classicelectronicsguy
Post subject: Re: RCA 45 rp190 stops mid cycle Posted: Jan Fri 19, 2018 4:49 pm |
Joined: Nov Wed 27, 2013 5:59 am Posts: 604 Location: Metzger Oregon
In the condition that Robert describes, the platter would still be rotating, but the tone arm would stop somewhere through it's reject cycle. The condition that Tbirdkid describes would be the platter stopping it's rotation, and the reject cycle taking off when you help it get going again. If this is the case, which seems to best match your description so I'm guessing it is, I have found that sometimes just cleaning all the idler, motor, and platter-rim surfaces can help - sometimes a little oil finds it's way in there and that's all it takes.
Top |
dberman51
Post subject: Re: RCA 45 rp190 stops mid cycle Posted: Jan Fri 19, 2018 8:30 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4170 Location: Boston, MA USA
It's usually necessary to replace the motor mounting grommets. They dry out and can no longer hold the motor in the correct position to drive the idler.
-David
Top |
cflusflwfl
Post subject: Re: RCA 45 rp190 stops mid cycle Posted: Jan Sat 20, 2018 2:25 am |
Thanks everyone for the advice. When I have time tomorrow I will try out some of your suggestions. Will let you know the results.
Top |
cflusflwfl
Post subject: Re: RCA 45 rp190 stops mid cycle Posted: Jan Mon 22, 2018 9:22 pm |
Thanks to everyone I got the player cycling. The hint was being able to stop the platter easily. It wasn't the tension on the idler, but a mistake on my part. I got a bit carried away with oiling the motor and some dripped down on the idler and motor shaft. Cleaned those up and I am up and running. Thanks for your help.
Top |
ndiamone
Post subject: Re: RCA 45 rp190 stops mid cycle Posted: Jan Tue 23, 2018 12:58 pm |
Joined: Feb Mon 06, 2012 7:24 pm Posts: 2525 Location: Gold Country, (Stanislaus National Forest) California 95235
Wallace wrote: Replace Grommet. Get a cat instead. At least they like cheese and cracking toast.
_________________ 2 kinds of men/tape. Low Noise/Wide Range. LN=kind. WR=abrasive. Engineers=same thing.
Top |
Users browsing this forum: No registered users and 12 guests |
