It is currently Feb Fri 22, 2019 11:35 am
 Post subject: Shielding shaded pole motor
PostPosted: Jan Tue 30, 2018 10:53 pm
Anyone had success putting a magnetic shield around the phono motor to
reduce the hum when using a magnetic cartridge. It has to be the motor cause
there's no hum till i switch on the turntable . I made a clip on steel cage made of
screening that reduced the hum somewhat but I'm open for more suggestions that
work better .
Was thinking of getting some Mu Metal foil but wrapping the motor with
this stuff will cause the motor to overheat .
 Post subject: Re: Shielding shaded pole motor
PostPosted: Jan Wed 31, 2018 12:32 am
I wonder if swapping the line-neutral wires at the motor might help any?
Post New Topic Post Reply  [ 2 posts ]  Moderator: Alan Voorhees
